Question about Sampo Computers & Internet
My monitor Goes blank after about 2 seconds
I have SAMPO monitors part number LME-1722 that have a BNC input that I'm useing for security. They are about a year old and now they are starting to go bad. What they do is when I power them up they display an image for about 2 seconds and then go blank. Is there a repair for this problem that I could try? Note the problem is the same on all inputs.
Thanks Dave
    An expert whose answer gotĀ voted for 100 times.
  • 152 Answers
Dave, You failed to state if these monitors are LCD/FPD or are they old tube type? I'm going to assume that they are of the flat screen lcd type. all monitors of the lcd type need what is called 'backlighting' to display the video information. In your case, maybe the inverter power supply board has detected a fault and go's into immediate shutdown mode. the inverter supply is what lights the long slim cold cathode fluorescent tubes (2) that are used for lcd backllighting in 98% of all small screen lcd monitors. There isn't a lot you can do about these types of failures. You can check with Sampo and see if they have a swapout program where you send old monitor plus some cash and they send you a refurbished ( new tubes+inverter board ) monitor. I myself kinda lucked out when a co-worker brought in his Dell lcd. we opened it up and found some bad capacitors that couldn't take the heat generated inside the case. Yes we unsoldered and replaced them with new and it worked. But that was pure luck. could have been a lot of other things wrong too. you might want to surf around and check out or other sites that deal with monitor CCF tubes and inverter repair. the lighting technology you are dealing with is similar to the new 'curlie-que' energy saving-screw-in light bulbs! Hope this helps you out some. I'm lmistyrel @ aol or louie12fix on fixya.
Posted on Mar 04, 2009
I want to connect a 6 pin s video to a bnc monitor and cant find a connector
Jan 31, 2013 | Lorex Home Sentinel Wide Angle Security...
Sampo sl5200
you can use it as monitor..If the unit have a tuner at the back so its a TV.
Jun 14, 2012 | Sampo LME- 32X8 32 in. HD-Ready LCD...
When I boot up my Windows XP PC the system starts to boot but then displays NO SIGNAL on the SAMPO monitor.
This is not a monitor problems.Check ur video cable connection.The computer might have a bad video card.
Sep 07, 2010 | Sampo LME-17S2 17 in. LCD Television
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Sampo LME-17S1 TV/Monitor w/RC-235B Remote-V-Chip - No Code
Master V chip over ride code is 8,4,8,4,100 (use the 100 button not 1,0,0) you should be good to go!
May 23, 2009 | Sampo LME-17S1 Television
Computers & Internet Logo
200 people viewed this question
Top Sampo Computers & Internet Experts
Paul Bade
michael galang
Are you a Sampo Computer and Internet Expert? Answer questions, earn points and help others
