Question about Kenmore 72722 Gas Dryer
Kenmore dryer goes on initially, shuts off and
Kenmore dryer 1107272100 goes on initially, shuts off and then it just glows when it is supposed to go on
  • Kenmore Master
  • 3,361 Answers
Replace the gas valve coils.
They are not opening after they get hot.
Posted on Mar 03, 2009
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Kenmore Dryers
My dryer s\tarts and has heat but the heat turns off and does not come on again. The heat (glow) element turns orange after that but the blue flame never comes on after the initial start. Is there a sensor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 12, 2010 | Kenmore 74212 Gas Dryer
Kenmore 70 series dryer starts and heats up then shuts off
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer wont heat or shut off at end of cycle
heatman101
Aug 08, 2010 | Kenmore Dryers
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Jun 29, 2009 | Dryers
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Kenmore 72722 Gas Dryer Logo
130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
