Question about Amana ALG443RAW Gas Dryer
No heat I bought a amana electric dryer thats about 5 yrs old. It worked fine when I got it home on the first load. But when I put a second load in, it has no heat just cold air. Any ideas on how I could fix it because I don't have a lot of money to spend on getting it repaired
    Brigadier General:
  • 8,619 Answers
Hi
First check and see if you have 110 volts coming to the gas valve at the connector. If you have voltage, then unplug the dryer and check the parts like coil.
If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point.
Also check for a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity.
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Posted on Mar 03, 2009
Model NED5100TQ0 WAS WORKING THEN WE PUT ANOTHER LOAD IN IT AND NOW IT WILL NOT START CHECKED THE BREAKERS AND THEY ARE FINE WHAT ELSE CAN IT BE IT IS ONLY 2 YRS OLD THANKS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 09, 2010 | Amana Dryers
My Amana NDG7800AW Gas Dryer won't heat up. The dryer is about 5 years old and we have no problems with it until now. Any suggestions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Amana NDG7800AW Gas Dryer
I have a front loading large capacity kenmore dryer about 6 yrs old. All of a sudden it has stopped heating. To Heatman from Hartman
heatman101
Aug 31, 2010 | Dryers
Whirlpool ler7646EQI Dryer runs for 5-10 seconds
sounds like u have a bad overheat sensor on the back on the electric strip housing and on fan housing they are round they are very cheap just take them off and replace both of them and that should fix your problem
Feb 25, 2010 | Whirlpool LER4634J Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
Whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Apr 26, 2009 | Whirlpool LER5636P Electric Dryer
Amana ALG443RAW Gas Dryer Logo
156 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
