Question about Dell Latitude D600 Notebook
Dell D600 Lock Indicators and Volume Buttons not working
Is there a specific driver for the caps-, num-, and scroll-lock indicator lights, as well as the volume control buttons (down, up, mute) on a Dell Latitude D600 laptop? (At the top of the keyboard area, together with the power button.)
I have had to reinstall Windows and (I think) all the Dell drivers, and now these indicators and buttons do not work.
Or is there any other reason why these indicators and controls would stop working?
  • flashman74 Mar 05, 2009
    Thanks for trying.
    I assume by "shortcut" and "hotkey" utilities you mean Quickset.
    It may well be my volume buttons and lock indicators above my keyboard are fried (athough the power button works fine...)
    Master:
  • 404 Answers
You need the dell's keyboard shortcut utility, dells hotkey and dells latest bios.
Posted on Mar 03, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 05, 2009
    I am sure you can figure this out yoursel by removing the panel because I don't understand exactly what you mean.
    rate us plz.
Dell latitude D630 When I turn on my laptop the lock icon with the A inside it is flashing. It will flash a couple of times then everything will turn off. The screen is blank the entire time. Any...
This indicates when the uppercase letter function is enabled.
See the manual here http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d630_User%27s%20Guide2_en-us.pdf
Page 99 says the three LED indicators for Num Lock, Caps Lock, and Scroll give the POST error status, and the reason for not starting up. Then contact DELL customer service for assistance.
Check these and then contact
Feb 27, 2015 | Dell Computers & Internet
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
My dell d600 latitude laptop indicates a lock button in the top icons and cant procede from there
purple function key next to the ctrl key
press that down and hold
press the num lock (toggle)
press the scroll lk (toggle)
press white cap lock only
See if any of these change the lighted lock indicator.
I assume that was what you mentioned in a focus of the request
Aug 19, 2010 | Dell Latitude D600 Notebook
I have the dell wireless Y-RBP-DEL4 KEYBOARD is there any warning light on it to say i have caps lock on
Unfortunately there are no lights on the keyboard, which is ridiculous if you ask me!
You can however download a driver from the Dell website that will add a Cap Lock, Num Lock and Scroll Lock notification to the taskbar area.
You can get the driver here.
Hope this helps,
Matt
May 01, 2010 | Dell Keyboard/Mouse
I may be totally retarded but I have no clue what the padlock with two arrows in it. It is on top of my keyboard next to the lighted indicators for num lock and shift lock.... anyone have any idea what...
The scroll lock key was meant to lock all scrolling techniques, though it is no longer used by almost any software. In the original design, scroll lock was intended to modify the behavior of the arrow keys. When the scroll lock mode was on, the arrow keys would scroll the contents of a text window instead of moving the cursor. In this usage, scroll lock is a modifier key like ALT and SHIFT (which modify the function of other keys) and, more specifically, a toggling Lock key like NUM lock or CAPS lock, which have a state that persists after the key is released.
Regards;
Hassan
Jul 22, 2009 | Fujitsu LifeBook N7010 4GB 320GB HDD PC...
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
2,285 people viewed this question
Alun Cox
