Question about Sharp FO-4400 Fax
Polygon Motor Error
Machine makes load noise and comes up with this error is it fixable?
    Genius:
  • 2,120 Answers
If you can get to the laser, it's a black box usually, you can oil the mirror shaft.
Posted on Mar 04, 2009
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
POLYGONAL ERROR / WHAT DOES THIS MEANS AND HOW I WILL REST IT... THANKS
Polygon error. There is a LASER inside the machine which hits a 5 sided minor spinning at about 35000 rpm. That minor is spun my the polygon motor. More then likely you have a bad print head. That is what the entire assy. LASER/motor/Minor/Sensors are called. Power off/then on if it comes back have a technician looks at it.
Feb 26, 2013 | Minolta MF2800 Plain Paper Laser Fax
Error code c4101
this is a polygon mirror motor failure replace the laser unit. to reset the error code open then close the front door while the machine is turned on if the error code comes back the parts will probably have to be replaced
Oct 25, 2012 | Konica Minolta Bizhub 362 Copier
I have an error code e7-02
Does the copier make a load noise like a jet engine starting up???? A E7 means the laser polygon mirror motor is not spinning at the correct speed. The only way to clear the code is to replace the whole laser unit or just the polygon motor... If you fell luck.... you can spray a small amount of WD-40 in the bushing of the motor > it is just a band aid... it will come back.... Good Luck
Nov 08, 2011 | Sharp AR-275 Copier
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
What is machine error 71 How to fix it?
Error 71 on a MFC-9600 means there is a problem with the motor inside the printer.
You can try unplugging and waiting a few minutes, then plugging back in again.
If it is still coming up with the error, if its still under warranty Brother will replace/repair it for you, otherwise you will have to pay Brother for the repair cost.
Mar 05, 2011 | Brother MFC 9600 All-In-One Laser Printer
Ricoh2035 problem code sc 329
SC320: Polygon motor error
- Possible causes -
· Polygon mirror motor defective
· Poor connection between the polygon mirror motor driver and the BICU board
· BICU board defective
Dec 28, 2010 | Ricoh Aficio 450 Copier
Functional Problem SC321-00
What is the actual code. Your heading says '321', then you list "320"?
"320" is the polygon (laser motor) that is defective. "321" is more likely the BICU board.
Could simply require the LD pitch adjustment be performed, depending on what else you have done. Do both the 400dpi, and 600 dpi. initial setting
SP 2109-3 (400 DPI)
SP 2109-4 (600 DPI)
Mar 30, 2009 | Ricoh Aficio 450 Copier
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
Sharp FO-4400 Fax Logo
520 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
