Question about Kenmore Washing Machines
Breaker trips washer trips breaker at low speeds
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Electric box keeps tripping out when machine turned on
You have a short or overload fault in the washing machine that causes the circuit breaker to trip out and this prevents a possible fire.
Feb 20, 2013 | Computers & Internet
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
High speed on pump motor just hums then trips breaker. low speed works fine.
possibly trying to draw more power than the breaker and wiring are rated for.. check maximum amperage draw from motor, then check breaker.
If breaker is rated lower than High speed amperage draw, then have a qualified electrician install proper size of wiring and breaker.
If not, then the high speed coil of motor may be defective, check for warranty of unit.
Jul 30, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Motor runs at low speed and trips breaker within 10 seconds
The motor is bad. It overheats inside and the contacts aren't releasing and this trips the breaker to prevent more damage, You can reset it because it had time to cool down and the contacts have released.
Jul 03, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 22422 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
16 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
