Question about Marvin Quartz Radiant Heater
I have a Marvin heater Model 2060, 120v, 60HZ, 12.5 Amp, 1500 Watts, and I need to find the Quartz heating element bulbs. Where can I find these as we really like this heater? The elements measure about 16 inches long and it takes 2 of them. Right now we are running it on only one element as the other one is burnt out.
5 Suggested Answers
SOURCE: Need Marvin Heater replacement element (model 2060)
Try logging on to this web site. www.onestopshopcatalog.com. I found the elements there. I just now purchased some. Website showed they had them in stock. We shall see!!
Posted on Jan 18, 2009
SOURCE: Marvin Quartz heater element
Just ordered the equivalent of Marvin part #E1750 from Quartz Infrared Inc. Their part # is 50909 and is $17.95 Phone # is toll free 866-747-4328
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Posted on Jan 07, 2010
SOURCE: the rotary switch off/750/1500 is bad. Marvin 2060
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Posted on Feb 08, 2010
Is it safe to plug a 1500 watt Marvin quartz radiant heater, model 4940 into the same receptacle as a lamp with a 100 watt bulb ? We had both appliances plugged into the wall and started smelling smoke...
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
Nov 19, 2010 | Marvin Quartz Radiant Heater
Dec 12, 2009 | Marvin 2060 Compact Heater
The upper heating element of my Marvin Quartz Steam 'n Heat Model # 5060 electric heater does not heat. Where do I get a replacement?
You can buy these elements from Quartz Infrared, Inc. at their online store.
Dec 07, 2009 | Kitchen Appliances - Others
How do you change the heating elements
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95.
There are links to the instruction manuals there as well. They include information of how to replace the elements.
Nov 22, 2009 | Marvin W.B. 7260 Quartz Heat N Light...
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
Oct 14, 2009 | Marvin Quartz Radiant Heater
Looking for bulb for marvin heater
Feb 27, 2009 | Marvin 7060 Utility Heater
Nonheating marvin, model 5000, quartz heater
Yes, I got my Marvin, model 500 quartz heater fixed, thank you. Please discontinue further communication.
Nov 29, 2008 | Marvin Quartz Heater With Built-In...
Marvin replacement elements are available from Quartz Infrared for $17.95.
Nov 23, 2008 | Marvin 2060 Compact Heater
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Marvin 2020 Heater
try this place - they have replacement quartz elements maybe you can find one here.
http://www.infraredheaters.com/quartz.htm
Dec 10, 2007 | Marvin 2060 Compact Heater
Heating & Cooling Logo
Top Marvin Heating & Cooling Experts
Daniel Gasser
Level 1 Expert
Oloyede Monsuru
terry stevens
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
