I have huawei ets2500 with cable usb - rs 232 but i hav'nt the driver tusb3410 boot device to install it thank you
    New Friend:
Thank
Posted on Dec 01, 2012
I have huawei ets2558 with cable usb - rs 232 TUSB3410 but is not working with windows 7
Posted on Apr 17, 2011
found this solution on scribd.com
http://www.scribd.com/doc/23712717/Installing-Huawei-Modem-Driver-of-PTCL-v-Wireless-on-Windows-7
Apr 17, 2011 | Computers & Internet
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Is there any way to interace with USB
You will need 3 items to interface your Wizard with a USB port.
1. A generic USB to RS-232 adapter cable (with 9-pin serial connector, to match the connector on the OZ-730 interface cable).
2. A USB to RS-232 driver for the above cable. (If you have Windows XP: HL-340.EXE, contained in 111.rar, which can be downloaded from www.usbserialdrivers.com. If you have another version of Windows, or if you have Linux, you will have to consult the documentation on www.usbserialdrivers.com to find the correct driver.
3. Software to communicate with the Wizard. You should be able to use the software that came with it, or purchase RuppLynx, or download Microsoft ActiveSync or a similar free program.
I used a cable I purchased on ebay, the HL-340.EXE driver installer, and RuppLynx software to connect an OZ-730, an OZ-570, and a Zaurus 5800 to my Windows XP laptop without any problem.
Nov 13, 2010 | Sharp Wizard OZ-730
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Driver needed
I found my disc. Problem solved. Thanks for follow-up.
Jan 11, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Tusb3410 vista
i have hauwei modem tusb3410 but can not install in vista window.
Dec 02, 2008 | Computers & Internet
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
Pansat 2500a FTA receiver
I would suggest to go here to get a lot more info on how to program this receiver.
Feb 22, 2008 | Televison & Video
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
Computers & Internet Logo
491 people viewed this question
David Payne
David Payne
