Question about Dell E153FP 15" LCD Monitor
SCREEN FLASHES, PINK STRIPES , SOMETIMES BLANKS TO BLACK THEN ON
THE SCREEN WITH APPEAR NORMAL, THEN IT WILL START TO GET PINK STRIPS VERTICALLY, IT WILL ALSO FLASH TO BLANK SCREEN THEN ON WITH DARKER PINK STRIPES
    Problem Solver:
  • 10 Answers
This issue could be either the Monitor inverter failing or it could be your Video card. If you have another computer available, plug the monitor into a different computer and see if you get the same behavior, if you do, then the monitor is failing and needs to be replaced. If on a different computer it works fine, then you may have a video card failing. Does it seem to happen the longer the monitor is on? Could be as it heats up, it starts to fail.
Posted on Mar 14, 2009
Vertical black stripe on screen
Hi my name is Roety,
I can help you with your issue ,
The black strip is either a bad panel or part of the lower buffer board is bad. There are ribbon cables that run from the panel to the buffer it may just be a loose ribbon connector
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 29, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
I want cheat codes of sims 2 pets
  • Cheat Gnome While at home or on a lot, press L1(2), R1, X(2), Up. Then, enter one of the following codes to activate the corresponding cheat function:
      10,000 additional Simoleons Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome. Select the Cheat Gnome, then cancel the selection. Press Up, Left, Down, Right, R1 again. A "Give Sim Simoleons" option should now appear.
      Pet Points Enable the "Cheat Gnome" code, then press Triangle, Circle, X, Square, L1, R1 while playing the game. A "Pet Points" option will now appear on the Cheat Gnome.
      Pet Emporium fully upgraded Enable the "Cheat Gnome" code, then press Right, Down, Right, Up, Right, Down, Right, Up while playing the game.
      Advance time by 6 hours Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome.
  • Alternate opening sequence At the EA logo, press X, Circle, Triangle.
  • View developers At the credits screen, press Right, Left, Up, Right, Down, Right, Down, Right.
  • Bonuses At the codes screen under the "Game Options" menu, enter one of the following codes to activate the corresponding cheat function:
    Result Code
    Collars
    Black Dot Cats ZZZ11ZZZ9Q11Q91ZB1A or EEGJ2YRZQQ1IQ9QHA64 Black Dot Dogs ZZZ11ZZQHZ11Q91ZB1A or EEGJ2YRQZZ1IQ9QHA64 Black Smiley Cats ZZZ11ZZQ9Z1AQ91ZB1A or EEGJ2YRQQZ1RQ9QHA64 Black Smiley Dogs ZZZ11ZZZ9QAAQ91ZB1A or EEGJ2YRZQQARQ9QHA64 Blue Bones Cats ZZZ11ZZQHZAAQ91ZB1A or EEGJ2YRQZZARQ9QHA64 Blue Bones Dogs ZZZ11ZZZHZ11Z91ZB1A or EEGJ2YRZZZ1IZ9QHA64 Blue Camouflage Cats ZZZ11ZZZHQ11Q91ZB1A or EEGJ2YRZZQ1IQ9QHA64 Blue Camouflage Dogs ZZZ11ZZZHZ1AQ91ZB1A or EEGJ2YRZZZ1RQ9QHA64 Blue Star Cats ZZZ11ZZQ9Z11Z91ZB1A or EEGJ2YRQQZ1IZ9QHA64 Blue Star Dogs ZZZ11ZZQHQ11Q91ZB1A or EEGJ2YRQZQ1IQ9QHA64 Green Flower Cats ZZZ11ZZZ9ZA1Q91ZB1A or EEGJ2YRZQZAIQ9QHA64 Green Flower Dogs ZZZ11ZZQHZ1AQ91ZB1A or EEGJ2YRQZZ1RQ9QHA64 Navy Hearts Cats ZZZ11ZZZ9Z11Q91ZB1A or EEGJ2YRZQZ1IQ9QHA64 Navy Hearts Dogs ZZZ11ZZQ9Z11Q91ZB1A or EEGJ2YRQQZ1IQ9QHA64 Orange Diagonal Cats ZZZ11ZZQ9ZA1Q91ZB1A or EEGJ2YRQQZAIQ9QHA64 Orange Diagonal Dogs ZZZ11ZZZ9Z11Z91ZB1A or EEGJ2YRZQZ1IZ9QHA64 Pink Vertical Strip Cats ZZZ11ZZQ9QAAQ91ZB1A or EEGJ2YRQQQARQ9QHA6 Pink Vertical Strip Dogs ZZZ11ZZZHZA1Q91ZB1A or EEGJ2YRZZZAIQ9QHA64 White Paws Cats ZZZ11ZZQ9Q1AQ91ZB1A or EEGJ2YRQQQ1RQ9QHA64 White Paws Dogs ZZZ11ZZZ9Q11Z91ZB1A or EEGJ2YRZQQ1IZ9QHA64 White Zebra Stripe Cats ZZZ11ZZZHQ11Z91ZB1A or EEGJ2YRZZQ1IZ9QHA6 White Zebra Stripe Dogs ZZZ11ZZZHZ11Q91ZB1A or EEGJ2YRZZZ1IQ9QHA64
    Fur colors
    Blue Cats ZZZ11ZZQHZA1Q91ZB1A or EEGJ2YRQZZAIQ9QHA64 Blue Dogs ZZZ11ZZQ9Q11Z91ZB1A or EEGJ2YRQQQ1IZ9QHA64 Deep Red Cats ZZZ11ZZQ9QA1Q91ZB1A or EEGJ2YRQQQAIQ9QHA64 ° Deep Red Dogs ZZZ11ZZQHQ1AQ91ZB1A or EEGJ2YRQZQ1RQ9QHA64 Goofy Cats ZZZ11ZZQHQ11Z91ZB1A or EEGJ2YRQZQ1IZ9QHA64 Goofy Dogs ZZZ11ZZZHZAAQ91ZB1A or EEGJ2YRZZZARQ9QHA64 Green Cats ZZZ11ZZZ9QA1Z91ZB1A or EEGJ2YRZQQAIZ9QHA64 Green Dogs ZZZ11ZZQHQA1Q91ZB1A or EEGJ2YRQZQAIQ9QHA64 Light Green Cats ZZZ11ZZZHQ1AQ91ZB1A or EEGJ2YRZZQ1RQ9QHA64 Light Green Dogs ZZZ11ZZZ9Q1AQ91ZB1A or EEGJ2YRZQQ1RQ9QHA64 Neon Green Cats ZZZ11ZZZHQA1Q91ZB1A or EEGJ2YRZZQAIQ9QHA64 Neon Green Dogs ZZZ11ZZZ9QA1Q91ZB1A or EEGJ2YRZQQAIQ9QHA64 Neon Yellow Cats ZZZ11ZZZHQAAQ91ZB1A or EEGJ2YRZZQARQ9QHA64 Neon Yellow Dogs ZZZ11ZZQ9QA1Z91ZB1A or EEGJ2YRQQQAIZ9QHA64 Pink Cats ZZZ11ZZQHZ11Z91ZB1A or EEGJ2YRQZZ1IZ9QHA64 Pink Dogs ZZZ11ZZZ9Z1AQ91ZB1A or EEGJ2YRZQZ1RQ9QHA64 Purple Cats ZZZ11ZZQ9ZAAQ91ZB1A or EEGJ2YRQQZARQ9QHA64 Purple Dogs ZZZ11ZZQ9ZA1Z91ZB1A or EEGJ2YRQQZAIZ9QHA64
    Fur patterns
    Bandit Mask Cats ZZZ11ZZQHZA1Z91ZB1A, TB6IPB1IAFDMRIQT6DG, or EEGJ2YRQZZAIZ9QHA64 Bandit Mask Dogs ZZZ11ZZQHQAAQ91ZB1A or EEGJ2YRQZQARQ9QHA64 Panda Cats ZZZ11ZZQHQA1Z91ZB1A or EEGJ2YRQZQAIZ9QHA6 Star Cats ZZZ11ZZZ9ZAAQ91ZB1A or EEGJ2YRZQZARQ9QHA6 Star Dogs ZZZ11ZZZ9ZA1Z91ZB1A or EEGJ2YRZQZAIZ9QHA64 Zebra Stripes Dogs ZZZ11ZZZHQA1Z91ZB1A or EEGJ2YRZZQAIZ9QHA64
  • Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    Reddish tint on the screen
    LG 700e
    power suply is dad
    resistanc is black not show it ohom
    plz help
    Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
    Thin vertical line appears on projector
    I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
    Nov 25, 2008 | Office Equipment & Supplies
    ViewSonic N1700w with Black stripe on right side of display
    Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
    Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
    MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
    The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
    Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
    Dell E153FP 15" LCD Monitor Logo
    286 people viewed this question
    Alun Cox
