Question about Kenmore 72982 Gas Dryer
My dryer wont run. i have checked all the wires and power with a meter. where do i look next? kenmore model 110.62622101
  • Kenmore Master
  • 8,220 Answers
It could only be the door switch or it's little tang
Posted on Mar 03, 2009
My kenmore dryer model#110.61202013 wont heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating
Feb 22, 2015 | Kenmore Dryers
Kenmore 68731 model 86873100 setting the drying to any of the drying methods, the dial does not move to automatically turn off the dryer.
You have a bad timer motor To verify you will get an ohm meter and remove the wires to the motor.
Check between the motor wires fer continuity. If you have continuity then the next test will verify if the gears are stripped on the motor. Apply power to the timer motor and see if it advances on its own. From looking at your model number I see nothing unusual about the timer.
to get to the[parts list I did 110.36873100. 110 is a the large prefix which ID's the dryer as being a whirlpool model. All kenmores ain't Whirlpool.
Aug 26, 2011 | Kenmore 659 Electric Dryer
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
Dryer wont start but the timer cliicks frigdiare dryer
It sounds like the thermal fuse. Without knowing model number I cant tell you exactly. Depending on how you access it. Near the blower housing you will see a little white sliver fuse ot a round fuse with two wires running to it. The one next to it has 4 wires running to it. Disconnect power before opening the dryer... Take a meter and see if it has continuity. If not its bad. Anything further please feel free to reply.
Jul 10, 2010 | Frigidaire GLER642A Electric Dryer
Kenmore dryer 70 series trips the 30 amp breaker
try running the dryer on air fluff so no power is going to the heater.if it runs you probably have a shorted heat element,unplug the dryer and check it with a meter,next time send model number and let me know what you find
Jul 03, 2010 | Kenmore Dryers
Kenmore gas dryer no heat . 90 series model 110.70902990 have power, did vacum lint from access panel@ FRONT
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Mar 16, 2010 | Kenmore Dryers
I have kenmore dryer model no. 417 and its not drying the clothes, its running but not heating, I checked the manual it said something about changing a fuse - can you give me more info on doing this, type...
Check your exhuast vent, if it is buily up with lint, clean or replace.
Next remove the wires from the heating element, test with a meter for a complete circuit.
Then remove wires from thermal fuse and test with meter.
Then repeat for any additional themal fuses, should be two total but some units have three,
If one thermal is bad replace both.
Mar 03, 2010 | Dryers
My kenmore elite 6942 won't power on. thoughts?
make sure your getting power to the dryer?also check that the motor is getting power,if it is and dryer won't start you could have a bad motor,you have to get in there with a meter and check it out,check the door switch,move the paddle you should here a click when you push it in and out,if not change it,also check the thermal fuse located on the blower wheel housing,you have to send more info,there's so many reasons why it doesn't start get a meter and read it out,send model number next time
Feb 03, 2010 | Kenmore 400 6942 Dryer
Dryer wont run any ideas?
It has got to be the door switch. The fuse won't stop this appliance from running.
Mar 03, 2009 | Kenmore 72982 Gas Dryer
Dryer wont run
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
Kenmore 72982 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
