Question about Sony VAIO VGN-CR220E/P Notebook
When trying to listen to the audio portion of a message or DVD or CD there is no sound. The computer indicates that the sound is working but we don't hear anything.
  • 54 Answers
Go to Start --> Control Panel --> Sounds and Audio Devices. In the first tab verify that the volume is not in its lower level and also verify that the option "Mute" is clear, then clic OK.
Good Luck!!!
Posted on Mar 03, 2009
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My computer wont play the sound when im trying to listen to music or play a movie.i would like to know how to get the sound back on
Have u recently installed a new DVD Drive?
If so and even if so, you need to have an audio cable installed connecting the DVD drive to the Sound Card in order to get sound when playing a MUSIC CD or DVD player from that drive. So double check that inside of the PC.
Next, go into the Audio Settings in the Control Panel and make sure sound is not muted.
Mar 15, 2010 | Acer (54.AA806.001) Sound Card
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
How can i make the audio out work on the Plextor px-708uf?
dependant on your Sound Card.
do you have the cable connected From The DVD Drive ( spdif digital ) Or analogue audio Cable ? this is a thin cable usually grey/white cable coloured red/black/ground or earth.
This connects from The DVD to the motherboard ( CD ) Or to your Sound Card ( CD Or IN ) If you don,t have this Cable connected you won,t get Sound from DVD To Sound card or on-board Sound from The motherboard. Also check your sound-cards drivers Are Installed correctly. Finally open the sound manager In My Computer, And check that a device is selected, Or Isn,t Muted.
This should Solve Your problem.
Mike @ compurepair.
Aug 19, 2009 | Plextor PX-750A DVD-RAM Burner
Teac lp- u200 cd player doesn't work
Sicne this is a new system, don't waste time on it. Return it for an exchange. The CD portion is not working. The reading message indicates that the unit detects a disc, but can not read it. This is usually a problem with the optical assembly or the processing board. Neither should be a problem at this time. Replace it under warranty.
Jan 05, 2009 | Teac Audio Players & Recorders
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Audio problem by DVD Play
You need to check to see if the dvd drive is set to digital playback because
it is probably trying to find your on board AC97 - 5.1 digital output. With
a music CD it doesn't have to be connected digitially because it uses analog
for stereo playback but most DVD's - if a movie - are set to playback in
digital. Open 'My Computer', right click on your DVD drive, select
properties, select hardware, highlight your DVD drive, click on properties,
then properties again, check- Enable digital CD audio for this CD-ROM
Jan 26, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Sony VAIO VGN-CR220E/P Notebook Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
