Question about Dell PowerEdge 1600SC Server
I have lost the scsi drive on a dell 1600sc and would like to convert to sata. During boot up the sata controller is reconizing the 2 hard drives but, come but with "no primary drive found"
  • allenwr2000 Mar 03, 2009
    Thanks for the responce, but sata drives don't have jumpers. And, the scsi drive died and 3 times the price. So, I attempting to go from scsi to sata.
    Bill
  • Dell Master
  • 19,396 Answers
The best thing to do is reinstalling SCSI, SATA can only manage two disk per channel on this server, and the data transfer time is longer.
If you set SATA, check jumper settings, that is probably reason why you get no primary drive.
Also check bios settings , do hdd auto detect and save in bios if you want to use sata.
If instead you want to go back to SCSI, download the drivers from the link below.
Download page from Dell.
Posted on Mar 03, 2009
  • Ginko
    Ginko Mar 04, 2009
    Hi there, sorry about the confusion, I was thinking about PATA all the time, since your Server does not have SATA, as you notice I kept talking about IDE, with max two drives per channel and jupers for CMS selection on HD.
    Your computer does not have SATA capability for that reason I kept talking about IDE/Parallel when I wrote SATA in comments.
    The only way to use Serial disks is by adding a SATA PCI card, like the ones listed on links below, this will replace your current SCSI card.
    If I was in your shoes I would also replace your hard disks with SATA hard drive.
    Using a SATA to SCSI converter is possible, but it will slow down the data access time to hard drives, if you plan to use an adapter, at that point better to keep IDE.
    I will be grateful if you can change the rating given , my previous comment was really out of this word, and after over 20 years in engineering, I was a bit ashamed when I re-read my original post.
    Good luck with your server upgrade.
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Can I boot from a SATA drive and access pre-existing SCSI Drives?
You need to install the driver of your scsi controller for win7/64. Then you'll see your datas on win7.
Jul 08, 2012 | Dell Precision Workstation 670 PC Desktop
WONT RECOGNIZE ADDED DRIVES ADDED 2 ADDITIONAL 146
If they are SCSI drives, you must enter the SCSI configuration software during a powerup and initialize the drives. From there, you can add them to a drive array or create a new array.
Feb 18, 2011 | Dell PowerEdge 1600SC Server
NO HARD DISK FOUND DELL POWERDGE 1600SC
Is the HD SAS/SCSI/SATA on a raid controller?
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
Either that or the drive(s) shafted.
What sort of disks are you using?
Aug 20, 2010 | Dell PowerEdge 1600SC Server
Ubuntu Server won't see scsi hard drives
you will need to load the drivers for the scsi controller assuming someone has written one for a dell server
Mar 28, 2010 | Dell PowerEdge 1600SC Server
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
DELL PowerEdge 1600sc - New motherboard no joy
Are you sure the new motherboard was of the same revision as the old one? Dell shipped 400FSB boards during the beginning of the 1600SC line and shipped 533Mhz boards during the end of the run. I would check the revision level of the motherboard to make sure it is compatible. If it's the same revision, I would start small and connect just one CPU and put the system at 512mb ram and see if that works. If this works, you can begin to add additional components as needed.
Good luck
Jun 19, 2009 | Dell PowerEdge 1600SC Server
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
How to install win2003 server freshly on dell power edge 1600sc?
You'll need to load the SCSI hard drive controller driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PWE_PNT_XEO_1600SC&os=WNET&osl=en&catid=&impid=
Aug 06, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
733 people viewed this question
Alun Cox
