Question about Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool dishwasher does not clean dishes.
Everything sounds as though it is working ok but the blades don't seem to spin and there doesn't seem to be any pressure in the water it just seems to trickle out checked hose up up to dishwasher and doesn't seem to be blocked.
  • Whirlpool Master
  • 3,361 Answers
Replace the impeller kit below the spray arm.
Posted on Mar 03, 2009
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
Dishwasher does not clean dishes
water probably isn't getting hot enough
Sep 07, 2015 | Dishwashers
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
Kudpo1flbl2
Check if you have at least 120 degree water temperature coming into the dishwasher. Check if the upper rack spray arm is turning during cycle. Does dishwasher sound normal, like you can hear strong water spray inside it?
Nov 13, 2011 | KitchenAid Dishwashers
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes in top basket cleaning OK but only those in upright position in the bottom basket seem to be cleaned and even then not always completely. Saucepans, jugs, tall mugs etc. don't seem to be...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Bosch Dishwashers
Why doesn't our Whirlpool dishwasher clean anymore?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 17, 2011 | Whirlpool Dishwashers
Our Whirlpool dishwasher (mod. #DU1055XTVS0) turns on but it's not getting the dishes clean. It also seems as though the top spray bar is not spinning. Is there a filter or something that's clogged?
heatman101
Apr 20, 2011 | Whirlpool DU1055XTVS Builtin Dishwasher
It's not cleaning the dishes. Sounds fine, but
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 18, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
383 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
