Question about Kenmore 72982 Gas Dryer
Dryer wont run any ideas?
Kenmore dryer model 110.62622101 checked all wires and power with meter. dont know what to look at next.
  • Kenmore Master
  • 8,220 Answers
It has got to be the door switch. The fuse won't stop this appliance from running.
Posted on Mar 03, 2009
Kenmore 68731 model 86873100 setting the drying to any of the drying methods, the dial does not move to automatically turn off the dryer.
You have a bad timer motor To verify you will get an ohm meter and remove the wires to the motor.
Check between the motor wires fer continuity. If you have continuity then the next test will verify if the gears are stripped on the motor. Apply power to the timer motor and see if it advances on its own. From looking at your model number I see nothing unusual about the timer.
to get to the[parts list I did 110.36873100. 110 is a the large prefix which ID's the dryer as being a whirlpool model. All kenmores ain't Whirlpool.
Aug 26, 2011 | Kenmore 659 Electric Dryer
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
Dryer wont start but the timer cliicks frigdiare dryer
It sounds like the thermal fuse. Without knowing model number I cant tell you exactly. Depending on how you access it. Near the blower housing you will see a little white sliver fuse ot a round fuse with two wires running to it. The one next to it has 4 wires running to it. Disconnect power before opening the dryer... Take a meter and see if it has continuity. If not its bad. Anything further please feel free to reply.
Jul 10, 2010 | Frigidaire GLER642A Electric Dryer
Kenmore dryer 70 series trips the 30 amp breaker
try running the dryer on air fluff so no power is going to the heater.if it runs you probably have a shorted heat element,unplug the dryer and check it with a meter,next time send model number and let me know what you find
Jul 03, 2010 | Kenmore Dryers
Kenmore gas dryer no heat . 90 series model 110.70902990 have power, did vacum lint from access panel@ FRONT
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Mar 16, 2010 | Kenmore Dryers
My dryer runs but has no heat. I have replaced the thermal fuse. I have checked the breaker, cleaned out the lint trap and checked the air flow which is good. I do not have a volt meter. Kenmore Electric...
Hello there :
There are severaol things that could cause this to happen
Things to check are :
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
I know that you have checked the thermal fuse so you dont have to worry about this.ok
Hope thatthis is very helpful
Best regards Michael
Dec 23, 2009 | Kenmore Dryers
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Dryer wont run
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
Mar 03, 2009 | Kenmore 72982 Gas Dryer
I have A kenmore Elite Model #110.65942400 Ser MR2103237.
before you take it apart make sure you have not lost 1 phase of the 220 volt line into dryer , dryers will run and appear fine on 110 volts be will not heat check fuse or breaker and re-set breaker even if it does not appear tripped , if fuse in line turn off power and remove fuses and check with an ohm meter , then if you have a volt meter check for 220 volts @ socket of dryer , then we will talk dis-assembly
Dec 01, 2008 | Kenmore 659 Electric Dryer
Kenmore 72982 Gas Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
