Question about Kenmore 72982 Gas Dryer
Dryer wont run
Kenmore dryer model 110.62622101 wont run. checked power with meter and looked everything over
  • Kenmore Master
  • 3,361 Answers
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
Posted on Mar 03, 2009
5 Suggested Answers
TheMobilian
  • 8205 Answers
SOURCE: my dryer wont run. i have checked all the wires
It could only be the door switch or it's little tang
TheMobilian
  • 8205 Answers
SOURCE: dryer wont run any ideas?
It has got to be the door switch. The fuse won't stop this appliance from running.
  • 8404 Answers
SOURCE: trying to install a dryer belt on a kenmore dryer
the belt goes through a tensioner which fastenes to the floor in a set of slots. Get the belt through that tensioner then around the motor pulley. Put the drum on the wheels in the back, lift the front (you need a helper) and put the front back on and fasten, replace the top.
Much easier to say it than to do it ... but you got this far, I have faith you can finish the job.
Thanks for using FixYa.com
a
Posted on Nov 01, 2009
woobie dog
  • 1273 Answers
SOURCE: does our kenmore dryer model no. 62622101 have a
Hi, W/D here.
On the top of the cabinet, below the controls, will be a lint trap that you pull out vertically.
It will look like this:
http://www.easyapplianceparts.com/PartInfo.aspx?Inventory=898444&SourceCode=3
Best regards, --W/D--
Please feel free to rate me.
Posted on Feb 03, 2011
Testimonial: "Thanx Guy's When I need parts, they will come from you. Dave Tenney"
Kenmore he2 dryer, model: 110.c87561602 beeps twice, wont start and is not showing any error messages
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 03, 2017 | Kenmore Dryers
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Jun 24, 2014 | Kenmore Dryers
Kenmore dryer 88752 dryer runs but wont heat up heating element was replaced problem not solved
Electric dryers are 220 volt, you could check both power legs for voltage. But I would go with checking the fuseble links, there should be two. Go to the Sears parts web page look up your unit and it will show you how many and there location. Check for continuity with a meter.
Dec 15, 2012 | Dryers
Kenmore dryer 70 series trips the 30 amp breaker
try running the dryer on air fluff so no power is going to the heater.if it runs you probably have a shorted heat element,unplug the dryer and check it with a meter,next time send model number and let me know what you find
Jul 03, 2010 | Kenmore Dryers
Kenmore electric dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 20, 2010 | Kenmore 63942 Dryer
Dryer wont heat
could be the heating element cant check with meter have to open her up and see if one of the heat coils is bad a new one will cost around 80$
Jan 14, 2010 | Kenmore 73952 Gas Dryer
Dryer wont run any ideas?
Mar 03, 2009 | Kenmore 72982 Gas Dryer
Kenmore 72982 Gas Dryer Logo
110 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
