Question about Frymaster Dean H17-SC Deep Fryer
Frymaster fryer over heats. Replaced thermostat. Runs for a couple of hours then overheats again.
    Problem Solver:
  • 5 Answers
Where exactly is your thermostat tube located?
Posted on Nov 10, 2014
  • 979 Answers
Make sure the t'stat is located properly. If it is too low in the vat, it will not read correctly. At the bottom of the vat, it can be as much as 150 degrees cooler than the top or more. Especially if the the t stat is below the burner, it will not read correctly.
Posted on Mar 03, 2009
I have a frymaster sr14esd, it turns on and makes noise but does not heat up. Is it my thermostat?
If the unit seems to be powering up and making noise, then you have power and it doesn't sound like a tripped breaker. About the only noise I would expect would be the element heating up and maybe the oil popping unless there is a fan. What kind of noise is it making? IF you have the equipment & know how, you could confirm power to the heating element or check the load the item is placing on the electrical service. One way to check the thermostat is you can turn the Tstat all the way down, turn on the power and see if you can hear the power engage as you slowly bring the temp setting up.
Nov 29, 2014 | Frymaster Dean 2424G Deep Fryer
Why fryer heat up and than the gas shut off
If the pilot light goes off too, then the thermocouple is defective. Otherwise its the thermostat or heat overload protector trips due to excessive temperatures.
May 22, 2014 | Frymaster Dean H14 Deep Fryer
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
With thermostat off still lets gas thru
Either the thermostat or the gas valve has failed. Locate and disconnect one of the wires going to the thermostat, if unit continues to heat the gas valve has failed, if not, the thermostat is likely stuck closed (on).
Oct 10, 2012 | Frymaster Dean SR42G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Breaker problem
This is probably the element shorting out as it heats up... causing an Overload on the breaker, as it's resistance lowers with heat. it could cause high current draw and blows breaker? Either that or there is some Phase Earth fault, in thermostat or similar? Or perhaps a wire moving and touching Earth as the unit heats up? Or the Breaker might be rated wrong?
Mar 02, 2010 | Frymaster Dean SR42G Deep Fryer
Fryer not starting
I'm suspecting one of the following causes:
1. The thermo couple/thermo pile
2. Gas valve sticking, intermittant operation, doesn't snap open when required all the time. THIS CAN ONLY BE PROVED WITH A MANOMETER and specialized meter that can measure thermocouple or thermoppile current, and volt meter.
I've worked on many a McDonalds Frymaster beeping fryers that intermittantly go into ignition failure that TURNS OUT TO BE THE ACTUAL GAS VALVE FAILING TO SNAP OPEN, and hang only once in a while. Gas valves are only good for so many operations, once that has been reached start failing. The indicator you gave, IT WAS USED BEFORE YOU GOT IT makes me believe it is your gas valve!
ps: manual for your unit
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5887.pdf
Jan 23, 2009 | Frymaster Dean GF14 Deep Fryer
Heating problem with frymaster h14-2
I called IG Service in Denmark, who have their own technical experts, And they will now solve it.
I found them via the frymaster homepaige.
www.ig-gruppen.dk
Jan 15, 2009 | Frymaster Dean 2424G Deep Fryer
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Frymaster Dean H17-SC Deep Fryer Logo
332 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
