Question about Refrigerators
The compresser in my Amana refrigerator, model # br22 clicks on and tries to run, but after 15 seconds a relay clicks and shuts off.
  • Refrigerators Master
  • 3,361 Answers
Replace the start relay. If it has a capacitor at the compressor replace that also.
Posted on Mar 03, 2009
I have an amana br22. The bottom freezer is freezing over and the refridgerator is not cold
check the fan in freezer,it should be in running condition,no goods should be in air crossing of it,no blockage should be in its air flow to refrigerator side
Aug 16, 2014 | Amana Refrigerators
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore Refrigerators
Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Oct 23, 2009 | Amana ABB1921DE Bottom Freezer...
Amana side by side fridge and freezer not cold.The model #ASD2624HES I have done some research and I think it might be the relay switch or the compresser.If anyone had has this problem with this model...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Part 4 on this diagram is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2624HES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATION&diagramPageId=00013&componentDescription=COMPRESSOR&documentId=M0608085&backToLink=Return%20to%20subcomponent%20list Here's how you can check it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Amana 26 cu. ft. Side-By-Side...
The bottom freezer on my Maytag BR22 is not
Look at the inside back wall of the freezer, If you see that it is built up with frost. You have a defrost problem. If not, check the coils under the bottom, make sure they are clean and not covered with dust. If so clean with vacuum and long brush. If they are clean, check the fan that blows on the compressor. Make sure it's running. If not you have a bad fan. Last be sure the fan inside the fridge is running.
Please rate solution
Sep 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water on top of freezer door and rubber inside is getting moldy fridge temp is 43 and freezer products are fine amana BR22* bottom out freezer/refrigerator
The seal is broken around the door and this requires total replacement to prevent the moisture, the cold air from escaping, the warm moist air from entering and causing your refrigerator to run more often than needed and running up your power bill. If I had your model number it would help me to help you find a door seal and fix the problem. So if you need my help you will need to locate the make and model number and write me a message here on Fixya that lets me know you have the number and are ready for help. There are 28 different versions of the BR22 so click HERE and then enter the complete model number. Thank you and if I can help you please let me know, If all else fails contact me at appliancepartsse@yahoo.com Thanks, Sea Breeze
Aug 06, 2009 | Refrigerators
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Relay on compressor clicks, but does not run
Hi!!! change the current relay in your compressor easy fix..its located inside the case where the wires go connect to the compressor..good luck..
Jan 04, 2009 | Amana ASD2626HE Stainless Steel Side by...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
