Question about T-Mobile Wing™ Smartphone
My screen goes out when I open it to use the keyboard
I got to text so I open the key board and the screen goes black I close it and it works again. How do I fix that?
  • kkgusey70 Mar 13, 2009
    I have the same problem and the suggestion they gave me was to get a new phone.
Throw it in to the dust bin
Posted on Mar 03, 2009
I got windows loaded but keyboard is locked. i can't type anything.
perform the following on the keyboard
  1. On the keyboard press the windows logo (image below)
  2. keep holding the windows key whiles you press the key U key in addition
  3. You should have a list of options.............choose on screen keyboard and with your mouse you can login and keep using your pc without a physical mouse.
Aug 04, 2011 | Compaq Computers & Internet
I have a studio 1749 my problem started after i removed the keyboard to clean it because of the dusty enviroment i work in. After putting the board back in i noticed the entire 2 bottom rows of keys didnt...
it's more likely you haven't put the ribbon cable back properly. try removing the keyboard again and reinsert the ribbon cable carefully - remeber there is a bable grip that needs to opened to remove the cable and closed again after insertion to maintain contact
Apr 11, 2011 | Dell Studio 17 (1749) Laptop black -...
My computer will turn on go thru all the motions like it is working it says windowsxp then goes to welcome screen then goes to my screen it wont show any programs or the start
It seems the Explorer.exe is not running properly or isn't loading. Press Ctrl+Alt+Delete (when it shows nothing on the screen) on the keyboard, the Task Manger will pop up, click "File" and select "New Task (Run)" and type in "explorer.exe" (without quotes), wait for few seconds, it should open up all the features properly, if this fails, go into Safe Mode and try again. To go into Safe Mode, restart the computer and keep tapping the F8 button on the keyboard until you see the Advanced Boot Options with Safe Mode as one of the options. Select Safe Mode using the arrow keys on the keyboard and press enter, you will see white texts in the black screen, wait until you see a warning to confirm whether you want to boot into Safe Mode or not, give a positive input and proceed forward, once windows is loaded, you better run a full system virus scan or I would also recommend System Restore.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 02, 2010 | Compaq Computers & Internet
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
My green, red and menu button on my lg cookie KP500 are not working and i can not turn my phone on, however my screen still works when charging, how can i fix this?
Hi,what makes the phone to stop working , that is the green, red and menu not functioning
is because there is a flex inside that connected to the screen of the phone that makes the key functions
is faulty and it needs to be replaced so that the keys can be function effectively once again.
but otherwise,
the front board that is board close to the screen is faulty, if need replacement
Take care.
Aug 04, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Samsung impression cell phone touch screen goes black when i use the keyboard.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is going black when you use the keyboard.
I would urge you to replace the flex and I am assuring you that your screen will not go black again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
Good luck.
May 21, 2010 | Samsung SGH-A877 Impression Cell Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Can't get full keyboard to work.
qwerty keyboard only works in horizontal mode
Apr 18, 2009 | Verizon Communications Samsung Alias Cell...
Phone works for about a minute then goes black and dies
The keyboard cable is worn or broken, take it to a service center for replacement. The keyboard cable has a small magnetic switch that detects when the phone cover is open or closed. If the keyboard isn't working and the internal screen is blank, the phone detects that the cover was closed.
May 02, 2008 | Motorola Mobility RAZR V3
T-Mobile Wing™ Smartphone Logo
48 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
