Question about Kwikset 907 907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea
I hit the lock button and the lock unlocks. i hit the password and the door locks
Take off cover turn 2 pin point around
Posted on Jul 31, 2009
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
Door locks lock and unlock by themselves electrical
Possible the system is deactivated.
1. Sit in the driver seat, turn the key on.
2. Hit the unlock doors button 3 time (within 5 sec of each other).
3. Turn the key off and hit the unlock 3 times again.
You should get a chirp from the horn.
If this does not solve your problem, you can try the same proceedure but hit the Lock button Vs the unlock button
Jan 08, 2010 | 1999 Ford Explorer
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My power door locks lock but not unlock the doors
first thing to check is the wireharness under the passengers floor mat,you wiil probably find a mass of corrosion and bad connections,been there done that!
Jul 29, 2009 | 2002 Chevrolet Venture Passanger
Hit the panic button, cant open doors. vw toureg
YOu need to lock the doors before you can unlock them. If this doesnt work unlock the door manually and close the door again then lock it
Jul 05, 2009 | 2008 Volkswagen Touareg
Door Lock Malfunctioning
power door lock solenoid may need replacement
Jul 04, 2009 | 2007 Mercedes-Benz C230 Sedan
04 Chevy Malibu won't unlock
Remote control door lock reciver an the BCM - body control module control the locks . The key switch is a electrical input to the BCM , the BCM controls the door lock actuators . Your best bet ,have it towed to the dealer .
Jun 18, 2017 | 2004 Chevrolet Malibu
Door lock won't lock/unlock with power button
I would think then, that it has to be a broken wire somewhere. Probably in the door jam of the door that doesn't work, or possibly inbside the door. First thing is to see if you have power back to it. Hook a test light up to the power lock inside the door. When you hit the button at the driver's door, it should light up. It could also be a rod has come apart in the door, or broken. You'll have to remove the inner door panel to investigate.
May 16, 2009 | 2001 Honda Civic
We have a 2007 Entourage and you cannot lock it with the car running. We installed a remote starter and it will not lock the doors when it is remotely started. Can this feature be disabled?
i think that this is to prevent you from locking your keys in the car with the engine running.
Some remote starters have a feature that when the car is running (and in park) you can hit the remote start button twice for one second each - then you can take the key out of the ignition and still have the car running.
At this point....if you would hit the 'lock' button on your door the doors would immediately unlock. However, if you get out of the car and close the door leaving it unlocked and then you hit the 'lock' on your original car remote the doors will lock and stay locked. So now the car is running the doors are locked and you have the keys in your hands. Then you can run into the store or house real quick with your car locked.
Once you come back, you hit 'unlock' on the original car remote. the doors will unlock - you can get it - and then before hitting the brake put the key in the ignition and turn it (dont crank it) as if you had when originally using the remote starter.
Maybe this will work for you.....
Oct 14, 2008 | 2007 Hyundai Entourage Limited Minivan
Kwikset 907  907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea Logo
132 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
