Question about Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
    Sergeant:
    Champion:
  • 237 Answers
The fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Posted on Mar 03, 2009
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
I am getting a 922 service fuser error on my lexmark optra s 1855
922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
Lexmark optra s1855 makes knocking noise when printing envelopes from the mp tray
this noise is usuallt cause by a flat spot on the backup roller of the fuser remove the fuser turn it by hand if you feel a flt spot when turning replace the fuser
Sep 23, 2009 | Lexmark Optra S 1855 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
I am getting a 922 fuser error on a Lexmark laser printer.
Hello. My dad had the same problem with his lexmark printer and he took it to a repair place where he was informed it is a problem with some part of the mother board causing the info from the computer to not be read by the printer. Long story short... is cheaper to buy a new printer than to fix the problem. He was also told this problem occurs in many lexmark models. Hope this helps you.
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
Fuser replacement
Wow i've worked on old printers but this is the the cream.
1-Open back door and remove the back cover ( two screws)
2-remove the top cover.
3- remove the cleaning pad cover and the pad,
4-take out two screws that hold fuser,
5-unplug fuser (two plugs, power and sensor plug)
6-remove fuser
Aug 07, 2008 | Lexmark Optra S 1855 Laser Printer
Lexmark Optra S 1855 Laser Printer Logo
178 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
