Question about HP DeskJet 5550 InkJet Printer
HP printer will only print jibberish!
I've tried cancelling all print jobs. Turning off and restarting computer. Unplugging printer and restarting. As soon as I turn it on, it spits out page after page with one line of jibberish.
Turn the printer off then uninstall the printer software, reboot the computer the reinstall the software. Your printer will be good to go.
Posted on Mar 05, 2009
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
The printer is printing and I can t cancel job, tried on off cancel button everything
Hey Surprise,
Trying turning the printer off and disconnecting it from the computer and from electricity for a few minutes (that should reset any print jobs stored in it's memory). In the mean while, check the computer for pending print jobs, and if necessary - cancel them.
Feb 04, 2011 | HP CP3525N Color LaserJet Printer
Every time I cancel a print job in process, the printer does not clear the queue. If I cancel it manually it shows "deleting document" but never clears the queue and all other print jobs backup. My only...
Several HP All-in-One models have this very same problem. The only way you can get rid of the unwanted job is to reboot your computer.
You could also try unplugging the printer and plugging it again to the computer, or just turning it off and on, but most of the times rebooting is the only option.
Jun 03, 2010 | HP Officejet 4315 All-in-One Printer
It takes unduly long time to cancel a print-command on any printer, when we work on Windows. What is the surest way to kill a printing command.
Open "Printers and Faxes" from the Start Menu. Open the print queue for your printer by double-clicking on your printer's icon. There will be a list of all the current print jobs. There you can right-click on a job and select Cancel, Restart, etc. Cancel will remove it from the list.
If you are not on the computer that is connected to the printer, you might not have permission to change the queue. Then you should go to the computer that is actually connected, and use this procedure there.
May 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer has a job waiting that I can't cancel. I've tried everything including turning off the printer to erase the memory, and completely restarting my computer. Nothing will delete this print job
your job is stuck in the printer que, to cancel this go to control panel, open printer and other, right click on the printer icon, delete the job in que (are you sure you want to delete, yes)..........and you are done
May 10, 2009 | Office Equipment & Supplies
Unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
Control Panel
Administrative Tools
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP 952c
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
139 people viewed this question
Ben Johnson
