Question about Saws
I am looking for manual shopsmith 10e saw - Saws
  • stelzer_j May 11, 2010
    are you looking for the owners manual or the shopsmith 10E itself?
  • Jim London
    Jim London May 11, 2010
    Hi, Are you talking about the 10 inch table saw on the Mark V?
You can find it at http://www.owwm.com/MfgIndex/pubdetail.aspx?id=2694 download it and print it.
Posted on Mar 20, 2009
    Problem Solver:
  • 12 Answers
You can also get the manual here: http://vintagemachinery.org/pubs/555/2694.pdf
Posted on May 12, 2014
I AM TRYING TO DOWNLOAD THE MANUAL FOR MY ACER ASPIRE SWITCH 10E
There are several models in the Acer Aspire Switch 10E line. If you start here: http://www.acer.com/ac/en/US/content/drivers . Either enter your machine model or use the drop-down menus to select Notebook, Aspire Switch and then your model. Click on the Documents tab. There should be a User Manual link to download a .zip file. Extract the contents to read the enclosed PDF. Note: the User Manual W10 includes notes for using Windows 10. It doesn't have the contents of the general User's Manual.
With the Acer Aspire Switch SW3-016-17WG, only the Windows 10 manual is available. For the SW3-013P, both manuals are available. Since the laptops are very similar, if a full manual for your model isn't available try looking at another model in the same part of the Aspire Switch line. The link to the full manual for the second system listed above shows up as http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=635681310277945244&Step1=NOTEBOOK&Step2=ASPIRE%20SWITCH&Step3=SW3-013P&OS=ALL&LC=en&BC=ACER&SC=PA_6 on my system right now.
I hope this helps. Please add a comment with the model number for your laptop if you'd like more assistance.
Oct 27, 2016 | Acer Computers & Internet
How do I put a blade in a shopsmith scroll saw
Open the cover, remove the clearance insert, there may also be a plug that spreads the channel in the table that you remove the blade from. Take the tension off the blade, rotate the wheel slightly and pull the blade off slowly, thread the blade through the channel in the table. Install the new blade in the reverse order. If the blade is a different width you may need to adjust the blade guides and the tension will be set differently.
Jan 18, 2016 | Blade Saws
What is the procedure of putting a new blade in a shopsmith scroll saw?
for more info please see the owners manual here: http://www.shopsmith.com/ownersite/manuals/845539.pdf and view page 31 -32
  1. Slide the new blade into position, working it up through the table slot, around the guard, and onto the wheels, as seen in Fig. B-26. The teeth must be pointing down and toward the front of the Bandsaw (and toward you). Position the blade approximately in the center of the rubber tires and in between the guide blocks.
  2. Check the tension scale alignment. With the blade slack on the wheels, the red indicator bar should be parallel to the left edge of the tension scale. If this is not the case, follow the alignment procedure described in Alignment section. Fig. B-26 Fig. B-27
  3. Tension the blade, turning the blade tensioning screw clockwise, as demonstrated in Fig. B-27. Notice that as you turn this screw, the red indicator bar moves, because it is actually the flat spring that tensions the blade. The blade tension is properly set when the edge of the bar disappears behind the scale at the marking for the blade width you're using. On a few operations, such as sawing thick stock with a thin blade, it may be necessary to increase the blade tension slightly beyond the normal setting. However, this increased tension will shorten the life of your blade. Always remember to reset the tension screw when you no longer need extra tension
  4. After you've spun the blade several times by hand, it should be centered on the three roller bearings, indicated in Figs. B-29 and B-30. The back of the blade should rest against the auto-track roller bearing and the lower blade guide roller bearing, and it should be no more than 1/64" away from the upper blade guide roller bearing. If the blade is not properly positioned on the bearings, follow the procedure described in "Adjusting Roller Bearings" in the Alignment section.
Is there a repair manual for this planer?
iFixit: The Free Repair Manual
https://www.ifixit.com/
iFixitiFixit is a global community of people helping each other repair things. Let's fix the world, one device ... We stopped by the European Parliament in Brussels to show some folks there how to fix their phones. The repair-focused ... Fix the Planet.
Shopsmith Repair Manual Planer - womensvictoryopen.com
dull69.womensvictoryopen.com/shopsmith-repair-manual-planer-xuvjjqe.pdf
Shopsmith Repair Manual Planer. Shopsmith jointer manual - free eBooks download. Shopsmith jointer manual download on apexjournals-3.org free books and ...
Dec 02, 2015 | Tools & Hardware - Others
How to replace the gilmer belt in a shopsmth mark 5 tool?
google the question, possibly youtube, or owner's manual from
manualslib.com
Mar 15, 2015 | Shopsmith Woodsmith Magazine Collection 25...
How do you set up a vpn with watchguard 10e?
http://www.fixya.com/support/p900930-watchguard_technologies_watchguard_fireb/manual-30983/page-156
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 27, 2010 | WatchGuard Technologies Watchguard...
I am trying to locate a 20 year old Total Shop 5 in 1 Tool Manual
Are you looking for a Shopsmith Owner's Manual? I have from 15 years ago.
Apr 28, 2009 | Saws
I need a free manual for a shopsmith mark v
I found something on amazon. Take a look: Amazon com shopsmith mark manual I hope I have helped. Cheers
Apr 16, 2009 | Saws
Saws Logo
990 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
