Question about AEG Washing Machines
Belt has come off my hotpoint ultima wt940 washing machine
How do i put the belt back on?
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Posted on Sep 17, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
  • 8 Answers
SOURCE: Hotpoint WT940
Blockage in pump
Posted on Jan 11, 2011
Hotpoint ultima wt940 washing machine
Either you dont have a high enough amperage breaker or the motor is going bad
Dec 10, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt940
the door is not locking , possibly caused by the interlock itself or motor brushes worn ( most likely if machine is a few years old at least ) could also be no power to lock via control board .
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
How to remove the top from a hotpoint WT940? 2 Rear screws already removed.
you need to give a sharp blow to the front of the lid towards the rear.. there are keyholed lugs holding it down in place... use you hand not a hammer...lol.. Thanks
Dec 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error F01
i have the same problem the machine gets part way through a cycle and then stops and Displays F1.
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Daughter has ultima wt940 error f-01 comes up any ideas
This refers to motor error, check motor wire connections & brushes. If these are ok it is its a pcb fault which requires replacing & programming.
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ultima wt940 Not spinning
Hi.
Possible slack belt which will slip with full load of water and washing, check tension, or maybe motor fault. the motor can sometimes work o/k on spin, but not on wash
Nov 23, 2008 | Washing Machines
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
