Question about HP Pavilion a305w (DM181AR) PC Desktop
Computer on can't see screen
Switch the pc on and it works ok BUT can't see the screen.
I have tried turning up the brigtness but nothing happens. No change at all. Got any Ideas? I am using a tourch to view the screen.
I had also the same problem.by removing both the RAM also i didn't get the beep sound.i hv replaced the positions of boththe RAM and didn't test again and took it to the servicing center.u cant imagine there is everything normal and the monitor shows the screen now.i m feeling lucky.hope it will help..or pull out the power cable of CPU and hold the power on button of cpu for 1 min. and then again start it...
Posted on Apr 14, 2009
    Sergeant:
    Champion:
  • 224 Answers
There seems to be either an LCD screen problem or the LCD inverter board. This issue needs to be properly diagnosed by a technician.
Posted on Mar 03, 2009
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
When I turn on the computer, the screen does not light up. I can sometimes just barely see some writing or a box, but nothing I can use.
I would assume you have used the FN and brigtness up button,
If this has not solved your problem it would more than likely be the inverter on its way out,, the inveter is located at the bottom middle of your screen bezel and would be best repaired by a professional as high voltage can be exposed
Jul 06, 2010 | Dell Latitude D531 Laptop Computer PC...
Black screen with the text "Check System. Then press F1" Nothing happens. How do I check System if none of the keys work. Will not even go into BIOS. Please hel. I have tried pressing both F12 and escape...
Try using F2 or F10 or Del. Check the Key board connection. You can use Ctrl+Alt+Del to restart the machine. If it doesn't work you have to change the keyboard and check again.
May 29, 2010 | Toshiba Satellite A60 Notebook
Its an 8gb.i had it plugged into the comeputer it
just remove the any usb pen drive which is connected to the cpu and try to switch it on .if there is no display remove the ram and try to fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | IBM NetVista PC Desktop
Turn on lap top no screen image
If you are running it on a battery, try connecting to power supply outlet. if nothing happens, it's time to unsrew the RAM compatment and resit them ok. Change the RAM if no image appears on the screen but not before testing with an external monitor ok. Good luck
Apr 28, 2009 | Toshiba Satellite M115-S3094 Notebook
Compaq NC6400 Turns on but will not display anything on screen.
hi thanks for using fixya!
I recommend that you bring your laptop to a service center to further check the hard ware of your laptop.
Best Regards!
Apr 12, 2009 | HP Compaq nc6400 Notebook
Vaio Sony wont go to the users acount
Hold button down for 5 seconds to switch off. The switch on and press F8 and choose safe mode boot. If it boots try a repair option or system restore to a previous working state
Nov 16, 2008 | Sony VAIO PCV-W600G PC Desktop
Brigtness of Compaq Presario v2100US
Check the power settings in windows.
Right click in the middle of the screen, click Properties, then Screen Saver tab.
Then click Power button at the bottom. Check the settings in there.
Mar 14, 2008 | Computers & Internet
HP Pavilion a305w (DM181AR) PC Desktop Logo
79 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
