Question about Microsoft Windows XP Professional
Win 16 subsystem error. have to close applications and reboot.
I get a 16 subsystem error and have to reboot to start up programs again. SP3
  • cortez glivings Mar 18, 2009
    This is the error-
    "The Win 16 Subsystem has insufficent resources to continue running. Click on OK, close your applications, and restart your machine.”
    I using software by xp systems "xp/win navigator". While researching the issue, I see it's happening with other software as well. But for me it's the one software. I haven't seen or don't remember anything in the error log. Next time it happens, i will make note.
  • ultimitloozr May 11, 2010
    What is the error message? Anything appear in the Event Log about this error? Does it only happen with a specific program or do multiple programs cause the error?
  • 489 Answers
Okay. The normal causes of insufficient resources in a Win16 app are the limitations on USER and GDI resources. This applies all the way from Windows 3.0 through WinME and the Win16 subsystem running under WinNT4.0 through Vista still are affected by these design constraints regardless of the actual amount of RAM installed in the computer.
But you can try this: Right-click on the executable for the application and select Properties. Click on the Compatibility tab. Check the boxes for 'Run in 256 colors' and 'Run in 640 x 480 screen resolution.' Try running the application again. If you still get the error, go back to the Compatibility tab and check the box 'Run this program in compatibility mode for:' and select the Windows 98/Windows ME in the drop-down list. Try the program again. If that doesn't work, go back to the Compatibility tab again and select 'Windows 95' in the drop-down list and try running the application again. Hopefully, it will run without errors in one of these configurations.
Posted on Mar 18, 2009
It has to do with how many GDI handles have been taken in the current session. Check out the article (with fix options) here: www.vttoth.com/wow32.htm
Posted on Jan 27, 2010
  • Doug Joseph
    Doug Joseph Jan 28, 2010
    Prior post amended to read as:
    Note: The article has good info, but overstates how hard it is to get the patched DLL into Windows. All I had to do was restart while pressing F8, and choose to boot into Directory Repair Services mode (which requires that are able to log in as an Admin).
    Once in that way, I had a fully functional instance of Windows (in Safe Mode) that allowed the exchange of the DLLs.
    I simply browsed to the system32 folder and renamed the original file by appending 'old' and then renamed the new file (which I had already pasted beside it) by removing the word 'new' (which was all that distinguished my new file from the original file name). I then repeated the process in the dllcache folder (which is a subfolder of the system32 folder).
I just started getting this error in Jun 09. In addition to the Win 16 Subsystem error, it gives an application error when my screensaver starts "Application: Picture". I did not make any changes to the system previously and could not find a solution. I remembered that Windows just downloaded an update. I restored to before the update and I have not had the problem again.
Posted on Jun 19, 2010
  • Sandra Mayo Oct 05, 2010
    What was the Windows update that caused the problem?
What is Spooler subsystem app?
I would uninstall printer software and reinstall with new downloaded software.
Dec 24, 2014 | Computers & Internet
While trying to transfer data from my Zaurus ZR-5000 to my computer a message comes on my computer screen saying " the Win 16 Subsystem has insufficient resources to continue running. Click OK, close...
You may be short of memory due to too many programs running in background. Google "windows task manager" to learn how to control startup programs. It is not too complicated.
Dec 03, 2017 | Sharp Zaurus ZR-5700
I executed simple C++ program but when i executed graphics program like to print circle,then the window closed and displayed a following message. 16 bit MS-DOS Subsystem C:TC BINTC.EXE The NTVDM CPU has...
If your operating system is win 7 or vista,
1,Locate c++ program file right click and goto properties
2,Untick or unselect RUN IN FULLSCREEN option.
Then your problem will be solved.
Jul 27, 2010 | ASUS M2N-MX Motherboard
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
16 bit MS DOS Subsystem error
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Apr 13, 2009 | Microsoft Windows XP Home Edition
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Orbi cam
what messenging program are you trying to use
Jan 27, 2009 | Acer Aspire 5100 Notebook
DVD Drive auto ejects on stratup of system & Remains open
did this happen after you have updated your win xp to sp3? try to do a system restore. go to all programs>accessories>system tools>system restore> go back to the date before the sp3 was installed. try also updating the driver for your optical drive
Jun 12, 2008 | BenQ DQ60 DVD RW Dual Layer Burner
Microsoft Windows XP Professional Logo
3,827 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
