Question about Logitech Inc MX610 Laser Cordless Mouse DH931350
MX610-wheel not scrolling upward well/erratic. Seeking exploded diagram, or best way to disassemble for cleaning. I am an advanced/experienced electrical repair tech. I was able to pull a gob of crud from one side of the wheel, but this did not resolve my issues. I figure there is internal cleaning needed. I cannot replace this mouse because I cannot seem to find it. My Revolution mouse scroll wheel sucks for 3DS Max use. I need the 610 for its 3rd button decent clickability and scrollability. Thanks!
  • Joseph Petric
    Joseph Petric Mar 05, 2009
    Another worthless function from Microsoft.
    That was something I didn't even think to check out (I'm a SysAdmin) :) My Logitech "setpoint" drivers and software are up to date.
    Thanks for trying! It is appreciated. though it didn't do much. The issue is more like slippage. I'm probably doomed to replace this mouse with something else.
    I really like it for work in 3DS Max and AutoCad. The the brick (VX Revolution) as I call it doesn't quite cut it due to the functionality of the wheel. Its designed to enter a free scroll function when pressed, so the 3rd button usage is very erratic on that mouse, besides the fact that it weighs a ton.. :)
    Again, Thanks for trying. :)
Had the same problem with mine (Microsoft 5000 (1058)) Turned out to be dust on the laser port on the bottom. Brushed it off and it works fine. Good luck!
Posted on Mar 07, 2009
  • 1,602 Answers
GO TO CONTROL PANEL AND OPEN THE MOUSE SECTION, VISTA HAS A DOUBLE CLICK SPEED, AND MAYBE TRYING A DIFFERENT TYPE OF POINTER, NOT A SOLID POINTER BUT CROSSHAIRS,POINTER OPTIONS, WHEEL, MOVE THE WHEELS TO 100 VERICAL AND HORIZONTAL. GO TO HARDWARE, AND TO PROPERTIES AND CHECK FOR UPDATED DRIVERS.
EVERY IMPORTANT
SEE IF YOU ARE NOT HAVING ANY INTERMITTING GLITCH WITH IRQ AND DMA CONFLICKS WITH THE SOFTWARE OR HARDWARE IN THE SYSTEM.
GO INTO PROBLEM AND REPORTS
AND OR
SYNC IF IT IS CONSIDERD A PLUG AND PLAY DEVICE.
MAKE SURE THE FIREWALL OR ANY OTHER ANTI VIRUS PROGRAM IS NOT INTERFERING WITH THE MOUSE APPLICATIONS AND OPERATIONS.
THE 3D PROBLEM MAYBE IN THE SETTING OF THE 3D IN THE DRIVERS OF THE OPERATION OF THE VIDEO CARD DRIVERS
HOW TO GET THERE:
OPEN PERSONALIZATION FOLDER IN THE CONTROL PANEL
GO TO DISPLAY SETTINGS OPEN FOLDER
OPEN ADVANCE SETTINGS, INSIDE HERE YOU WILL FIND THE FOLLOWING FOLDERS:
ADAPTER,
MONITOR,
TROUBLESHOOTING,
COLOR MANAGEMENT,
CATALST [TM] CONTROL CENTER, OPEN IT,
OPEN CATALYST CONTROL CENTER AGAIN,
INSIDE HERE YOU FIND THE FOLLOWING SUBJECTS:
INFORMATION ON SFTWARE & HRDWARE
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES
3D SETTINGS (OPEN THIS 1 FOR 3D OPTIONS)
COLOR
AVIVO VIDEO
POWERPLAY
HOTKEY OPTIONS
PROFILES
PERFERANCES
VIEWS
HELP ONLINE
AND A DEFAULT BUTTON IF YOU HAVE PROBLEMS SETTING THE SYSTEM TO ORIGNAL SETTINGS IF YOU CANNOT REMEMBER WHAT YOU DID.
RODGANDYSR567
Posted on Mar 05, 2009
My scroll wheel skips, jumps, scrolls backward or on its own. Can I fix it?
Take the roller ball out of the bottom of your mouse if it's the older style and clean the dirt and dust of the roller wheels with a q tip and alcohol. If it is an optical mouse try putting a piece of white paper under it when you use it this may help. If not it is time for a new one.
Mar 14, 2016 | Computers & Internet
Scroll wheel stopped working. It feels weird now when i try to scroll it. How do i fix it?
Disconnect the mouse from the computer and turn it upside down. The screws to disassemble the mouse are under the pads on the bottom of the mouse. When you disassemble the mouse, you will find that the scroll wheel axle is gummed up, and the interruptor wheel is probably dirty. Use an old tooth brush and alcohol to clean the scroll wheel components, and let the components dry. You can use glue to re-attach the pads after you have reassembled the mouse.
Sep 05, 2015 | Universal AULA Ogre Soul Professional...
Exploded diagrams of acer5553
Exploded diagrams?
This means to me you may wish to have the Service Manual.
Has Disassembly, and assembly guide in it.
This is for the Acer Aspire 5554, which I believe you'll find will work for the 5553,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the 'paragraph' that starts with Aspire 1200. (1200 in blue)
Go down to the line that starts with - 5332. (7th line down )
Scroll over, and left-click on - 5554
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (5554), it may take up to 30 seconds, before the first page comes up.
Done.
Doesn't use the same Intel technology that the 5554 does.
It does not support Intel Core i processors.
It does not have an Intel HM55 motherboard chipset.
Case, and disassembly looks the same.
Disassembly guide for the Acer Aspire 5534, also looks the same,
http://www.insidemylaptop.com/how-to-dismantle-acer-aspire-5534-series-laptop/
Copper contact pads you short out to rest the BIOS password?
Ummmm, no. No info.
http://support.acer.com/acerpanam/notebook/2011/Acer/Aspire/Aspire5333/Aspire5333sp2.shtml
If what I have given is not what you seek, simply state in a Comment, as to what it is you do seek.
Regards,
joecoolvette
May 04, 2012 | Acer Computers & Internet
Where is the thermostat/defrost gauge located on my Santa Fe Advance dehumidifier? The company sent me a new one but no directions on where to find it. Thank you
You will have to remove the plastic "cover" from the top of the unit to access the interior parts on the Advance model. Make sure you disconnect the power cord before beginning the disassembly. You can call the service group at 1-800-533-7533 to speak with a technician if you need help.
Jun 24, 2011 | Therma-Stor Santa Fe Dehumidifier
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
Whirlpool SM8280867 stopped agitating and makes noise.
you can find disassembly video on youtube,chances are you probably need a coupling,part no.285753a u can find exploded image/parts from sears .com
Mar 06, 2010 | Washing Machines
Scroll wheel not functioning at all
Initially, go and buy some elctronic switch cleaning spray and spray all around the mouse especially the wheel and this may clear all the dust and skin particles that block mouse and leyboards during PC usage. If this does not work, re install it and see if that is any better.
Feb 17, 2010 | Manhattan Mouse
Cursor problems
Is this invariant of what surface you have it on, or whether you clean the lens with a q-tip?
Jun 15, 2008 | Logitech Inc MX610 Laser Cordless Mouse...
Logitech MX610 problem.
Hi, I have had the same problem with a Logitech Cordless Desktop setup. The mouse and keyboard had been used in an office environment for about two years, then the mouse would double click unexpectedly, would not hold items when trying to drag them and the right click would sometimes fail to work ...then sometimes it would work perfectly. I tried all the other suggested cures such as cleaning out the inside of the mouse, new batteries and reinstalling the driver which did not prove to be effective. A good clean improved things for a couple of days but the symptoms returned. At this point, I dismantled the mouse and resoldered some suspicious looking joints on the circuit board inside, especially those attaching the microswitches for the mouse buttons. Since then, none of the problems have recurred. I presume that repeated pressure on the switches over time had cracked the solder joints which caused the mouse to behave erratically. You could try this, but dont get the joints too hot or you will damage the switches or other sensitive components. Simon.
Mar 22, 2008 | Logitech Cordless Mouse
Wireless Intellimouse Explorer 2.0
Actuallly, I took apart my WIE 2.0 for the first time to clean out a soda mishap. While inside, I noticed that the housing that the rubber wheel sits VERY tight to the top and bottom of the housing it is placed in. I would say that this is probably a design flaw, by the choice or thickness of rubber they used for the wheel, or not allowing enough room in the wheel housing.
*I realize that this is VERY difficult to imagine if you have not disassembled your WIE 2.0 before*
- remove the batteries
- undo the screw in the battery compartment
- flip up the top shell upwards, from the bottom and lifting (the top edge is secured by plastic latches you SHOULD NOT break)
- unplug the wheel sensor from the mainboard (tricky, again do NOT destroy any pins/capacitors)
- pull out the wheel casing, disassembling each part (they only come together/apart in ONE way, do not force or reverse axis positions)
- once you get the wheel/sensor out of all the housings, you can do one of 3 things:
1) shave some of the hard plactic from inside of the innermost casing, to avoid the wheel rubbing at the top and bottom of the "slot" the wheel is settled in. Take care not the remove any latches/axes needed to attach everything together!
2) shave the actual wheel rubber thinner, for the same reasons
3) remove the rubber completely, leaving the plastic sections of the wheel (which is what I did)
- clean and re-lubricate the wheel and casings if you like (but I find it works better without ANY of that dirty lube they use)
- put everything back together again, and now that you have reduced the friction in the wheel, it spins MUCH more freely.
- enjoy your scrolling freedom!
side effects:
- if you shaved or removed the wheel rubber, you will have less leverage for side scrolling
- if you removed the wheel rubber, you will have less traction on your finger for up/down scrolling
- if you removed the wheel rubber, it is much easier for dirt to get trapped in the wheel casing (meaning more frequent "take-apart cleaning" sessions)
Nov 16, 2007 | Microsoft Wireless IntelliMouse Explorer
Computers & Internet Logo
965 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
