Question about Iomega (33600) 160 GB USB 2.0 Hard Drive
My iomega hard drive is dead how can I fix this?
Its an external usb hard drive, i only had it a few months and then suddenly my computer doesnt show the drive or theres no noise coming from the HD. A light flicks and then goes dead.
  • uptown_herma Mar 03, 2009
    thanks but im very much an amateur and would not dare to do as u suggest however much as I'd like to!
    Scholar:
  • 135 Answers
Disconnect any leads and remove the outer cover.
Check the hard disk inside is securely pushed into the receiving socket.
Replace outer cover and give it a try.
Sometimes a knock can dislodge the drive and cause the problems you describe.
Best wishes.
Posted on Mar 03, 2009
  • My reply is Mar 03, 2009
    It's really, really easy.
    Locate the very small cross head screws (usually on the back or side).
    Simply remove them with an appropriately sized screwdriver and the cover will just slide off.
    Just push firmly inwards on the end of the exposed internal drive to be sure it is seated properly and then replace the cover.
    TIP: Don't lose the screws ...... they're tiny :o)
    I know you can do it !!!
I recently restored to factory settings on my HP laptop.once restored I then input my Iomega drive into the USB port to access some of my saved files.
Just to be on the safe side, why not plug in your iomega drive into another known working computer and see what happens. If it works fine and is properly recognized then the anomaly lies within the software of your laptop.
U might want to contact HP - but be fore warned that they are terrible for support if your unit is "out of warranty." If that is the case I would simply google the anomaly and in all likelihood you will get links that will help you fix it yourself.
Apr 06, 2015 | Iomega Usb 500Gb 3.5 Desktop Select...
Pavilion Slimline will no longer recognise iomega 1Tb External Drive 31882100
I would buy a new hard drive enclosure. Pull the drive out of the old and into the new. If it works great, if it doesn't return the enclosure and replace the drive.
Dec 29, 2012 | Iomega Computers & Internet
I have a minimax 1TB external hard drive. All of a sudden it doesn't show up on my desktop any more. Any suggestions?
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 24, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Iomega HDD 160 GB
Hi
If it is connected to the mains ,make sure it's correctly connected.
Also try another USB port on the computer.
If it used to switch on before or even make sounds to show that it was working and now it doesnt then it's either a problem with the harddrive case or the drive itself.
To retrieve the information on it(if the problem is infact the case) then you will need to open the case and remove the harddrive from it and then buy an external USB case for it ,or if you are technically good with computers attach it internally to the computer.
Good Luck
Please rate answer if it helped ,if not then let us know.
Jan 27, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
External Hard drive not showing in my computer
thanks for your question...
please change the hard disk compartment and do it carefully.
May 20, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Iomega (33600) 160 GB USB 2.0 Hard Drive Logo
683 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
