Question about Acer Aspire E380 - Athlon 64 X2 4200+ 2.2 GHz (S6479431) PC Desktop
My e380 stopped working weeks later I found moth bd jumper off
I need a map or schematic of where the motherboard jumpers go because I dont have it right as soon as I turn power on processer fan kicks in and no info to monitor help!!!
    Master:
  • 404 Answers
Http://support.acer-euro.com/drivers/desktop/aspire_e380.html
Posted on Mar 03, 2009
Motherboard jumpers diagram
http://h18000.www1.hp.com/products/quickspecs/11709_div/11709_div.html
Tells me everything I didn't want to know, lol!
Basic motherboard specs, but no motherboard manufacturer info.
Hmmm,..............
OK,
1) http://www.ebay.com/itm/COMPAQ-HP-D220-MOTHERBOARD-Spares-335186-001-M101-/370624992122?pt=LH_DefaultDomain_0&hash=item564af8937a
2) http://www.ebay.com/itm/HP-SPS-BD-SYS-D220-335186-001-Motherboard-Socket-478-/330531140050?pt=Motherboards&hash=item4cf530f1d2
3) http://www.ebay.com/itm/HP-Compaq-Evo-D220-CMT-Socket-478-Motherboard-335186-001-P4-2-4GHz-CPU-I-O-/380529715263?pt=Motherboards&hash=item589956a83f
Put your mouse in the middle of the photo/s.
Mouse around. (Ha)
Tell me where the jumper/s are.
By the CMOS battery? If so I think you can see where the jumper cap/s sit.
Post back in a Comment.
Regards,
joecoolvette
Dec 16, 2012 | HP D220MT PC Desktop
Reset the cmos
This depends on what you're trying to do. If you've changed something in the BIOS itself and it no longer works, but you can't remember the default, enter the BIOS and press <Alt><F>. If you have a password on the BIOS that you can't remember, there is a jumper on the board itself that will clear the password. There is also a jumper to clear the NVRAM, which may help you.
The schematics for the jumpers are here: http://support.dell.com/support/edocs/systems/wsT3500/en/SM/a_sysbd.htm
If you've never used a jumper, you're looking for a little plastic bit on the motherboard. If you pull up on this plastic bit, (fingernails are very helpful here) you'll see two gold pins sticking up off the motherboard. This is a jumper. To deactivate the password or clear the NVRAM, remove the appropriate jumper connector (the plastic part) and power up your system for about 10 seconds. Then turn it off, replace the jumper and cross your fingers.
Hope this helps!
Feb 21, 2012 | Dell XPDFK Precision Workstation T3500...
Jumper mapping for via5000 epia rev.E
BIOS jumper (1x1:3) is next to the CMOS battery east and slightly south of center, Freq MHz jumpers (4 x1:2) are on the north side just west of the DIMM banks, front panel etc. jumpers (multiblock + 2x1:2) are in the South-West corner.
Sep 20, 2011 | VIA EPIA-5000 Motherboard
I need a schematic for hp pavilion a735w some things got unplugged from the motherboard
dear heart,
they dont do schematics.
You need to contact manufacture with computer name and model number; then you need the board numbers,, dates and REVISION NUMBER ...It will cost money...but you get a little book with the jumper connections
Nov 25, 2010 | Computers & Internet
Do you have to set the motherboard jumper settings? or are they preset
Jumper settings can usually be left alone. All jumper settings can be found in the motherboard manual found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X8DA6
Oct 13, 2010 | SuperMicro X8DA6 DP LGA1366 MAX96GB EATX...
Took the two green jumpers off-what are they for? Tried finding a board schematic online. no luck. Not sure how to hook them back up. There off now and machine seems to run OK
The jumpers you have taken off might usually be jumpers for clearing the CMOS (think of it as the BIOS settings). This usually not be a problem. You can look for your motherboard's support for "Resetting BIOS". Most of the time, there will be some things involving jumpers.
Mar 07, 2010 | MSI Microstar KT6 Delta (MS-6590)...
Pls i dont know my setup password so i cant enter the bios setup and the person that asembled the computer is no where to be found pls how can i get the password.
Remove the onboard Battery, the one like the coin chaped battery on the motherbaord. then place it back & your bios will be reset.
Feb 02, 2009 | EliteGroup 661GX-M Motherboard
Can i format without the bios password?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Nov 08, 2008 | Panasonic Toughbook W2 Notebook
Jumper configuration for motherboard
Matt,
I don't have a solution for you, but tell K. her sister is looking for her, and to give her a call.
-Laura
Jun 27, 2008 | Biostar M7VIQ Motherboard
T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
May 05, 2007 | E-Machines T2893 PC Desktop
Acer Aspire E380 - Athlon 64 X2 4200+ 2.2 GHz (S6479431) PC Desktop Logo
154 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
