Question about Pioneer AVH-P6600DVD Car DVD Player
No sound. checked the fuse.
My avh6600dvd wont play sound. Im not sure what happened maybe a wire touching but I took it in to get tested and they hooked it up and a little smoke came out. not good i imagine. Everything works, display, dvd, cd except the sound. Turned it all the way up and still nothing. Help?
  • Anonymous Mar 04, 2009
    Anyway to save it?
  • 33 Answers
Sounds like the output section of the amp is toast. Especially if there was smoke involved.
Posted on Mar 04, 2009
Ok so my dodge ram cummins 07 running passenger front and tail light quit working and we checked all the fuses and they seem to be all good and also the alternator quit charging and it all happened in a...
Did you smell any smoke? Sounds like a short circuit took out the alternator. A good auto electrical shop can save you lots of heartache. Maybe just replace the alternator but if something took out the old one and kills the new one that could get expensive. Good shops know the tricks like wiring in a flasher that will allow testing without melting the rest of the wires. Good luck.
Jan 03, 2015 | Cars & Trucks
No side speakers
Make sure you test your wires and that they are running paralel, un wire and rewire, and make sure no speaker wire is exposed or touching.
Dec 12, 2013 | Edifier M1360
I have a deh1350 and when connected to a 94 corolla it simply won't turn on. I took it back and got a replacement one but the same thing is happening. Is there something wrong with the cd player or is it...
I know it sounds dumb, but make sure the key is forward. Ive dorked out and did this a few times. Some decks have a red AND yellow wire coming out deck wire harness. Sometimes you have to hook just the red for power, sometimes just yellow, sometimes both, maybe check that out. And it cant be the ground, cuz if you missed the wire, it would ground when you hooked up the antenna. Oh ya, sometimes when playing around with wires, you mess up and pop the radio fuse. Check that. Cold be blown
Jan 20, 2011 | Pioneer Car Audio & Video
Glitch???
sounds like you don't have power going to the red wire. should be a switched power source so it turns off with the key.
Apr 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
Push the button nothing happens
check the wires again
you just might have a bad fuse
odd but it does happen
Oct 07, 2009 | Whirlpool LER4634J Electric Dryer
My saturn over heats only when i have the ac off
Check for a fuse that is blown first.Then look for a cooling fan relay.Check the relay to see if it will turn on the fan,by using a test light.Clip the end on the test light to a good ground,maybe the ground on the battery.While the car is running,pull the fan relay out just a little so you can touch the prongs on the relay with the test light pointed end.When you touch the right prong,the fan will come on.The test light is actually grounding the relay.This is the safe way to activate the relay without damaging the relay circuit.If the relay clicks,and the fan comes on,replace the coolant sensor.If the fan does not come on,and the relay clicks,then run a hot wire to the positive wire on the fan to see if it will work.If you don`t get the fan to run that way,and you are sure the fan is hooked up correctly,then replace the cooling fan.If you cannot get the relay to click,and the fan is good(because you have checked it)replace the relay.If I can help,let me know.
Aug 30, 2009 | 1995 Saturn Sl
Not turning over
If you know how to use a 12volts test light, do this. Ground the light to a good ground. Touch the battery positive, it should light up. Now test the heavy + battery directly on the starter, it should light up;that's the heavy wire coming from the battery positive terminal. Now test the smaller wire on the solenoid which is directly on the starter for power while you have someone cranks the engine. If power, it sounds like a starter problem. Check all fuses with test light. Also the neutral must be considered if the first tests do not work. Keep me updated.
Jun 12, 2009 | 1995 Chevrolet Monte Carlo
Car wont start,shows no sign of power
sounds like bad battery broken on the inside .it will touch for a bit .then gose out .you hit it makeing contact again . have batt amp tested battery test. later
Mar 29, 2009 | 1999 Dodge Neon
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Pioneer AVH-P6600DVD Car DVD Player Logo
125 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
