Question about Kenmore HE2 Plus Front Load Washer
HE2plus. I keep getting rL on clean washer cycle.
No clothes in washer and I have unplugged machine. Washed a load in between and still get rL on ''clean washer cycle.
  • ostrov Mar 09, 2009
    I have exactly the same problem. Somebody has advised to open the drain pump and inspect for foreign objects. I have tried that, but don't know how to open the pump. Any suggestions will be appreciated.
  • deviliish Mar 10, 2009
    how do u get to filter
  • 15,935 Answers
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
What does an rL error mean?
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions. The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub. Turn the basket by hand and see if you notice anything.
Mar 10, 2014 | Kenmore HE2 Plus Front Load Washer
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I was running the clean cycle on my Kenmore front loading washer and it keeps stopping and reading rL. It wasnt having any probs working on reg cycles, only when I was trying to run the clean cycle. What...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
When cleaning the washing machine it stopped and the RL came on. What is RL?
RL means at the start of the CLEANING WASHER cycle a load isdetected inside the drum.
Try removing clothes from drum and start the cycle again.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
Error code RL keeps occuring when washer is in CLEANER MODE
rl code is load detected in drum during cleaning washer cycle. Book answer is to remove clothes and start the cycle again. Here's everything that Whirpool doesn't want you to know or do to your machine. Don't blame me if you do anything that damages your product. This is a link to the on-line 'technician' only service manual for your washer.
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code "rL" means???
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
Feb 18, 2009 | Kenmore HE2 Plus Front Load Washer
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Front load washer problem
rl means there are clothes in washer during cleaning cycle...however .there is a glitch in the program and have seen that rl code with no clothes in washer...don't bother calling repairman it's a program issue with the computer last i heard there was no fix forthcoming and customer were to be told to use normal cycle as they would the clean cycle
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
We get an rl error code when attempting to clean washer. Why and what does it mean?
Is there some thing in the washer ?
rl error
If at the start of the CLEANING WASHER cycle a load is
NOTE: Detects by weight.
Possible Causes/Procedure
Remove clothes from drum and start the cycle again.
Aug 15, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
1,539 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
