Question about Kwikset 907 907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea
Kwikset keyless entry is backwards
The lock button opens the door and the code locks the door
    Sniper:
  • 68 Answers
The config terminal is wrong. Take the cover off and move the 2 pin terminal over one pin.
Posted on Mar 23, 2009
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
My lock works backwards. Hit the lock and it unlocks, punch the code and it locks
I'm assuming you are dealing with the Powerbolt, since you didn't mention the model of lock you have. This problem is probably because the "handedness" of the door is set opposite of your installation. That is, you may have what is called a "right-hand door" and the lock is set for a left-hand door, or vice versa. In other words, what side the door hinges are on and which way it therefore swings open.The Kwikset lock has an internal jumper which needs to be moved to another position to change the function.
Cut and paste this link into your browser, the scroll down to Step 11:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HifLAAS.aspx
Step 11 says:
11. Door handing: I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
This link will illustrate how to remove the cover to change the jumper:
http://www.kwikset.com/Support/Faq/50160000000IB4hAAG.aspx
Apr 17, 2011 | Kwikset Locks & Locksmithing
I have a kwickstet smartcode touchpad keyless entry. When I push the lock button it opens and when I do the code it locks?
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Mar 31, 2011 | Kwikset Locks & Locksmithing
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Feb 04, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do i change the entry code on my Kwikset 909 keyless lock? Just bought the house and want to made a code number of MY choosing. Thanks.
slide the cover off the interior of the door. you will see a program button. you can program two individual codes. to program the first code, press the program button once, then enter your code on the exterior keypad and press the lock button. for the second code you would press the program button twice, then enter the code and press the lock button.
Jan 23, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We have a kwikset keyless entry lock and need to reset it.
Try searching the type of kwikset lock from this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Keyless+Entry
Jan 22, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the code in my kwikset 909 keyless entry
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset 907  907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea Logo
572 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
