Rollers in final unit - the fixing unit - are badly scored - partly by the paper guides. Can I get the rollers themselves, or is it better to get the complete unit ? It is a second-hand machine, and I think may have been wrongly re-assembled after service.
  • bobkennedy Mar 03, 2009
    The answer does not explain why I need to get the whole unit when a local repair centre could provide the rollers.
  • 37 Answers
To make it sure and to give you satisfaction you should buy the fusing unit, but make sure that your machine is in good running condition so that your money will not be wasted.
Posted on Mar 03, 2009
    Genius:
  • 1,269 Answers
Rollers are hard to find if your unit is an old one. Its worth investing your money for a new one.
  • 6,784 Answers
You can purchase a separate roller but, replacing the entire unit will cost less.
  • 916 Answers
You can get the rollers themselves but it is cheaper to replace the unit.
    Sergeant:
    Novelist:
  • 277 Answers
You will have to get the complete unit.local repair center can porovide the rollers part if you want.
  • top class Mar 03, 2009
    as if you go to service centers they will not provide you the rollers .they will ask you to buy whole unit.but if you go to local repair center they will provide you with rollers .they will not demand you to buy whole unit.only rollers they will give you.
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Letteres printed on a Monochrome printer offset type onto themselves
Which print finishing setting do you use: Draft, Normal or Best?
Mar 07, 2008 | HP LaserJet 1320 Printer
I have a message on screen sayng " ADF Jam" there is no paper jamming the system. I cannot make this message go away, and so i cnnot use any other function of the printer. How might I clear...
Hi travlynn2,
  1. The ADF
    unit is the grey paper tray located on the top of the scanner unit.
    Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
  2. Check the position of the ADF document guide:
    1. Lift up the ADF unit. Locate the document guide on the underside, as shown here:
    2. The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
    3. If your document guide looks like example (2)
      on the right, lift it out on the right-hand side. Tuck it in behind the
      grey section, so that it matches the example on the left (1).
    1. Close the scanner unit.
    2. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    3. Test the printer by scanning or faxing via the ADF unit.
  3. Check the ADF edge guides:
    1. The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
    2. Slide the edge guides to enclose the loaded
      paper (in the direction of the yellow arrows below), without causing it
      to bunch or crease. The paper should be aligned with the relevant paper size marker:
      Figure 9. The ADF edge guides.
  4. Check the ADF unit feed rollers:
    1. Open the cover of the ADF by pulling up the grey lip, as shown below:
    2. Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
    3. Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
    4. Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
      1. The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
      2. The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
    5. When complete, close all the covers.
    6. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    7. Test the printer by scanning or faxing via the ADF unit.
  5. Check that the ADF unit sensors are not obstructed.
    1. Open the cover of the ADF unit.
    2. Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
    3. If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
    4. When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Epson ACULASER CX11NF All-In-One Printer
Why Error message Tray1 Load LTR
Check the paper settings, tray is set to letter. Tray 1 is running our of paper, check paper guides and properly load paper on tray.
For further assistance, please contact Lexmark Technical Support
Sep 13, 2011 | Lexmark C500n Laser Printer
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
How do you replace the platenroller guide rollers?
to replace the feed rollers under the platen. 1 - remove the platen by squeezing the black plastic clips at the ends of the platen and pulling the platen straight up. 2 - pull the paper pan out, 3 - push down on the feed roller set and rotate it towards you. replace bad rollers and put things back in reverse order. there is a guide on the rod the feed roller unit sits on, make sure the guide on the feed roller unit goes back in this. there are pins at the right side and left side of the right and left feed roller units. these are for positioning the paper pan in the slotted tabs on the bottom of the paper pan. make sure the gear on the platen goes on the left side, position the clips to center on the frame, then push straight down. make sure both clip are fastened in. the only reason you should be replacing these rollers is if they are splitting apart or falling off due to the pins at the ends of the rollers wearing off (never seen this happen on a WW6) if you are having some sort of other problem, you might ask for a different solution before doing this - its harder than it sounds.
Dec 20, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Jul 09, 2010 | Canon Office Equipment & Supplies
Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Printer keeps jamming
You can order replacement parts and install them yourself or have a repair printer tech do it. But to save money you can do it.
http://www.sparepartswarehouse.com/HP,Photosmart,C6180-All-in-One,Q8181A,Printer,Parts.aspx
I don't have your part number that's on the unit use the link above and put in the right part number. I used Q8181A
What you need is called: HP Printer Belt or Roller: ASSY-PICK ROLLER
Note with heavy printer usage the rollers will wear out quick. If they do the paper will get stuck and jam. In the meantime you can use W40D on the rollers wipe and dry with a cloth that does not have lint. There is a product I use but not so to customer that fixes these problems but it's not the right solution it's better to replace the parts that are bad.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
18 people viewed this question
jasbo
jasbo
