Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP not installed on my Toshiba SatelliteL 40
When i am going to install i got a message that ur Hard disk not connected or the power problem but my system working properly when i am installing the XP.
  • 21 Answers
I have wrote this issue in my blog.. pls visit this post:
http://solve-pc.blogspot.com/2008/01/installing-windows-xp-on-toshiba.html
Posted on Mar 07, 2009
I replaced vista with xp on my Satellite L305D-S5895 and now it crashes during xp install. why?
This model Toshiba laptop has a SATA hard drive.
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Apr 03, 2013 | Toshiba Satellite L305D-S5895 Notebook
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
Hdd locked cannot install windows
If your HDD has a password on it, that is stored in the HDD firmware and renders the HDD useless without it.
Jun 02, 2017 | Toshiba Portege Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
How do i install seagate st3500320as 500 gb sata internal hard disk on a msi 845pe max2 series motherboard. i have installed the hard disk, but it is not detected. presently i have a 40 gb ide hard disk...
ther are jumpers betwwin the data cable and power cable of hard disk...ur 40gb hard disk will be on primary...if u are attaching ur hard on same cable u should put jumper on Secondry
Mar 10, 2009 | MSI : 845PE Max2-FISR...
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
XP Installation Problem
Make sure that hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct
Dec 18, 2008 | Toshiba Satellite L45-S7409 Notebook PC
I lost my install disk, please help!! anyone! please help!
well happy to help u .u just have to long on to ur products web site and go to driver and support coloumn and ur problem will be solved.if u can tell me the make and model and ur location i can also provide u the link. pleasure helping u .
Oct 29, 2008 | Veo Connect Webcam
Hello
Accordint to your post yoursys has enabled as sata drive.xp can not indentify sata disk while installing windows. to solve this you have to change ur bois settings. to chnage press f2 while booting system and check for sata option change it to ide and save settings. now you can install xp.
Jun 23, 2008 | Computers & Internet
Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Please try changing the HDD. If same thing happens the problem may be with ur O/s Cd or the Mother board
Please let me know this is used machine or New one. If new one please take a different O/S cd and install it.
If you are installing XP and your HDD is SATA then you need sata drivers.
Mar 07, 2008 | Toshiba Satellite 1905-S301 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
