Question about Panasonic UJDA730 CD-RW/DVD-ROM (Combo) Burner
My usb removable flash disk got a problem the disk is found when its pluged but when i try to open it tell me to incert a disk,also my mp3 player its a reem mp3 didnt work need a driver but i cant able to found any so plz help me soon.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 64 Answers
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
Posted on Mar 22, 2010
Can't get the usb port to work
If you expect the music files on the flash drive you plugged into the USB port to start playing by themselves, good luck with that. You have to open a media player application (say Windows Media Player), open the removable disk that is your flash drive from within the application, select an .MP3 file from the flash drive and play it.
Feb 03, 2015 | Audio Players & Recorders
Remove write protect from pen drive
1. Start > Run -> type "CMD" and press enter
2. type< diskpart
3. type< list volume
4. type< select volume # (# is the number of the USB HDD you've pluged in)
5. type< attributes disk clear readonly
(If you need help while typing commands then type "HELP FORMAT" on command prompt)
Aug 27, 2013 | Kingston DataTraveler 101 G2...
Pen drive not opening or formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jul 10, 2009 | Pen Drive IVO MP3 Player
Hiiiiiiiiiiiiiiii
Hi
Try it on any other PC. if other usb devices work with your PC you may have dirty contacts of your USB.
Aug 29, 2008 | Delstar DS 31024 MP3 Player
Help!
You're getting that message because you've likely tried to open a card reader that has no media card in it. If you're sure that you're trying to open the right removable drive, right click on it and click explore, and it should open right up. I've gotten the same error when trying to load files to my flash drive from time to time. Hope this helps! www.dfwsupergeek.com
Jul 25, 2008 | Lasonic VP-02GL Digital Media Player
Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 01, 2008 | SanDisk Sansa m250 MP3 Player
My mp3 2gb gogear
Batter is not replaceable - go to www.usasupport.philips.com and get the firmware upgrade for the player - or, you can just open the Philips Device Manager and click on the "Update" button
Jun 27, 2008 | Philips HDD1630 MP3 Player
Flashing ilo.
I found that connecting the MP3 player to the computer with the patch cord causes the player to reset and eliminates the problem. It only takes a few moments,just disconnect when the pc tells you it is safe to remove the device.
Jan 19, 2008 | iLO (2 GB) MP3 Player
Battery won't charge
http://www.anythingbutipod.com/forum/showthread.php?t=10960
If that doesn't fix it try the USB cable
Jan 16, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mp3 player keeps saying no files
Windows Update from last year killed this player. The company is out of the mp3 business, so there is no way to fix this issue. You could try reformatting the player:
Ensure the Digital Audio Player is ON.
Use the supplied USB cable to connect between Digital Audio Player
and PC.
Double click My Computer icon on the desktop. You can find a
"Removable Disk" is added to your computer.
Right click on the Removable Disk then select Format.
Select FAT
Sep 12, 2007 | Verge DFP-200 MP3 Player
Panasonic UJDA730 CD-RW/DVD-ROM (Combo) Burner Logo
66 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
