Question about Element Electronics FLX3210 32 in. LCD TV
Need owners manual for Element FLX 3211B 32in LCD TV.
Dipu007
  • 2110 Answers
SOURCE: NEED OWNERS MANUAL for PHILIPS LCD TV
http://www.p4c.philips.com/files/4/47pfl3603d_27/47pfl3603d_27_dfu_aen.pdf
Posted on Jan 16, 2009
SOURCE: Element FLX 3202 no power
This was the same thing that happened to me. When I took it apart and checked the power supply the capacitor (largest on the board) was blown. I called Element Electronics, which turned out to be Polaroid, and they sold me the entire control box assembly for appx $115 with a $100 core deposit to ship my old assembly back. My core deposit was credited back to my account within 2-weeks. BTW, when mine went out I had no power light on at all. Lastly, If you have questions about doing this yourself let me know, while I'm no electrical engineer, I did a ton of research trying to solve the problem.
Posted on Feb 03, 2009
SOURCE: my element 19 inch flx-1910 tv will not power up
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Posted on Feb 14, 2009
SOURCE: Element FLX 3211B has no power after 14 months of
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Posted on Apr 27, 2009
SOURCE: Lost the screws for the stand, need the specific screw
Just called the Element Parts Department because I had the same problem.
M5 x 18 mm
Enjoy your properly secured TV!
Posted on Jul 28, 2009
How to start auto scan on remote
Refer its user manual for details. If you don't have its user manual, check this site to download it in PDF. Element FLX 3211 Manuals Support and Troubleshooting TVs
Electro help
Dec 08, 2014 | Element Electronics FLX-3211B 32 in. LCD...
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
I had sound but no picture on my Element Electronic FLX 3211B LCD Television Set. I replaced two capacitors, and now I have lit screen by turning on the tv on the side panel. Remote does not control the tv...
You might have bad capacitors still that you cannot see. The only way to be sure is with an ESR meter. Check all the connections on the boards again to be sure that the sensor for the remote did not come off.
Sep 08, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Looking for the location of the Inverter Board in my Element Electronic FLX 3211B LCD Television Set. Is there a youtube video on how to locate and replace one ?or a photo that shows where it is.
What I have found on this tv is the inverter board is integrated with power board you might want to head over to badcaps site on this one.It could be as simple as replacing 2 transistors and a fuse.
Sep 01, 2012 | Element Electronics FLX-3211B 32 in. LCD...
M5 x 18 mm
Mar 15, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
2. Replaced Diode
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element Electronics FLX3210 32 in. LCD TV Logo
157 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
