Question about Blaupunkt Santa Cruz MP36 CD Player
I have a Vauxhall Astra with a Blaupunkt CD30 fitted, stereo works but beeps @ every 10 seconds and display shows 'radio safe' for a second or two!!!!, any advice would be much appreciated thanks.
  • 33 Answers
I could be in demo mode possibly. If you have your owners manual it will tell you how to "defeat demo mode"
Posted on Mar 04, 2009
Can I connect my Galaxy Note3 to a blaupunkt CD30 06 Vauxhall combo stereo?
got to check Bluetooth settings on radio and pair with device
Mar 10, 2014 | Car Audio & Video
Astra coded radio cant enter code??
I would suggest that your radio got a voltage surge when your battery was recently removed and re-connected. I would either:
1) Remove radio (if you have the special tool), unplug and re-connect harness, or
2) Pull the fuse in the fuse box for the radio (may be two), or
3) Disconnect the negative post to the battery, wait 30 seconds and re-apply (very quickly).
If the display does not reappear, I'm afraid the radio is damaged. Let me know.
Dec 18, 2013 | Car Audio & Video
I hav the code ect (Blaupunkt 300 ina astra van), now need to know how to install / reset radio
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 21, 2011 | Blaupunkt Car Audio & Video
How to enter code for blaupunkt cd30 vauxhall
Blaupunkt CD30 Code Entry
Turn on the radio, the display will show 'CODE' followed by '0000'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station ^ ] button to save.
Jul 13, 2010 | Car Audio & Video
How do I input in my radio code for Blaupunkt 2003 vauxhall corsa, if my code was 1742 and I can only use buttons 1, 2, 3 or 4 to use.
Blaupunkt CAR2003 Vauxhall Code Entry
The [ AS ] key must be held in while switching on the set. The set should then display 'SAFE' briefly followed by '10 - - - -'.
Press the [ AS ] key to accept. The set will now operate.
blank.gif _uacct = "UA-277454-2"; urchinTracker();
Apr 11, 2010 | Car Audio & Video
I have got a vreg corsa with a stereo that hasnt got a display.could u please tell how to put the code in because the numbers only go to 6 on the stereo and in the code there is a 9 and 7 please help the...
Find your Blaupunkt instructions on this free Code Entry website.
http://www.radio-code.co.uk/code-entry-help.php
The exact instructions will depend on the radio model.
If your display is NOT working and you have the CORRECT code then the usual method to enter the code "blind" is to ADD 1 to each digit.
So Code 1234   would be entered "blind" as 2345
A typical Blaupunkt with a separate display is the model CAR300
Below are the Code Entry Instructions for that model
(Don`t forget to ADD 1 if you are entering the code "blind".)
 INSTRUCTIONS TO ENTER A BLAUPUNKT CAR 300 (no display ) RADIO CODE
Press and hold
Press  Button
Nov 14, 2009 | Car Audio & Video
My vauxhall stereo is stuck on safe mode how do i unblock it i have lost the code
1. turn ignition on (dash warning lights on)
2. If radio turned on, turn it off.
3. Press AS button in, and hold it in while turning radio on.
4. Wait approx 10 seconds (do not release AS button).
5. Radio should beep, and display should now read 10 - - - - (assuming no tries have been made in the past with the wrong code)
6. use pre-set button "1" to scroll the first digit in the display to the number you want (it goes 0,1,2,3,4,5,6,7,8,9 then back to 0)
7. Use pre-set "2" for second digit, etc.
8. Once display reads 10 followed by the four digit security code press and hold AS button for about 10 seconds, until the radio beeps.
9. If correct code entered display will now read "code" briefly, followed by"memory-U" briefly, then radio will reprogram it self.
10. If radio goes back to "safe" the code number is incorrect, or you mis-keyed it.
Note: entering the code incorrectly 10 times will render the radio useless.
After the first 3 tries you need to leave the radio on and the ignition on for increasingly long periods of time before it will let you try again. 7 safe need you to wait at least 30 mins, and more like 1 hour.
WARNING - you only have a max of 10 attempts to get it right, but if still no luck after the 8th attempt, STOP and contact a Vaux dealer.
Sep 06, 2009 | Car Audio & Video
Siemans VDO CDR500 Audio player for Vauxhall Astra 1999
Switch off the stereo so that the date and time show on dash. Press and hold the volume button and the AS button together for about 5 seconds. It should now ask you to input the code. Do this by using the numbers 1 2 3 & 4 on the stereo. When the code is entered, press and hold the AS button on its own and wallah, your cd player is up and running
Jul 16, 2008 | Car Audio & Video
Car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
May 12, 2008 | Car Audio & Video
Blaupunkt Santa Cruz MP36 CD Player Logo
1,497 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
