Question about Kenmore 43142 Front Load Washer
Kenmore front-load washer stops at rinse cycle
4-yr old Kenmore front-load washer model # 417 44142400 stops at rinse cycle. Washer will fill wash and drain water, but rinse cycle not working. Washer stops at rinse cycle after draining wash water and tumbling a couple of times, and makes humming noise. Dial does not advance after this. Washer spins fine if you manually advance the dial to the spin cycle. Problem occurs on all wash/rinse/spin settings tried.
  • 7 more comments
  • Anonymous Mar 13, 2014
    Ge washer stops at rinse cycle . If I hit the start/stop button it will start back up.
    I have a older get top load washer that stops at the rinse cycle,if I hit the start/stop button it will start up again
  • Anonymous Mar 18, 2014
    Washer will do the full wash cycle but shuts off before final spin.
  • Anonymous Mar 19, 2014
    My washer will not advance through each cycle. I keep having to press Start. I just replaced the main control board but the problem still exists. Intermittantly it will wash but once it gets to the spin cycle it stops.
  • Anonymous Mar 24, 2014
    washes water drains will not spin
  • Anonymous Mar 25, 2014
    Only fills for few seconds and stops.also no rinse.can hear a humming noise sometimes.rinse cycle no water fills
  • Anonymous Mar 27, 2014
    Stops mid cycle
  • Anonymous Mar 29, 2014
    My American home enduro one thousand one hundred model does not rinse automatically The tub seems to just be filling water in and draining it out but it doesnt rinse Four hrs have past when I found out since I left home for an errand and the wash has not properly rinsed The water just kept on filling and draining Help
  • Anonymous Mar 31, 2014
    Will not advance from wash cycle
  • 188 Answers
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series front loading washer
The pressure switch is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Kenmore 43142 Front Load Washer Logo
1,875 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
