Question about Acer TravelMate 2480-2968 Notebook
What is a multimeter and how can i get it. Can I get steps how to test the powerpack with a multimeter on my acer travelmate 2480-2968
    Master:
  • 404 Answers
Its a digital volt meter which also has other options. its useless when it comes to motherboards because it doesnt test caps and diods
only voltage, wiring and pos and neg detection
Posted on Mar 03, 2009
Acer 4320 won't power up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Possible troubleshooting steps and repair solution:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
My acer travelmate 240 dose not have sound
Ever consider to see if headphone jack works? If this is the case it is possible it is the speaker.
Sound card or similar is possible but an expert should be the only one to look for that.
Apr 17, 2012 | Acer TravelMate 240 Notebook
Travelmate dont switch on when i connect my adapter. even no led glows when the adapter connected. tried a new adapter still not working send me ur valuable suggestions to sheku1984@gmail.com
Remove your pc battery and try connecting directly to AC supply via your adapter. If you have a multimeter, you could measure your adapter's potential difference to be sure of the right voltage output ok. If nothing happened here, then you should open the pc's RAM compartment and remove the RAM(s). Re-install them properly and test one after another. You could also get a fully charged compatible battery and test alone, ie, without AC this time. If all these didn't work, then the culprit is the power unit. Good luck.
Jun 10, 2009 | Acer TravelMate 2300 Notebook
Reprogramming Acer Travelmate 2420
Hey,
read this page on how to reinstall or upgrade windows xp
http://support.microsoft.com/kb/316941
Thanks and good luck.
Ekse
Apr 26, 2009 | Acer TravelMate 270XV Notebook
Broken DC jack on Acer notebook
There is a site on the internet that gives a step by step on how to remove the covers and locate the broken part. Type in repair Acer. Also there are labs the will repair this most common problem...Is the jack broken or is the adapeter broken...
Apr 23, 2009 | Acer TravelMate 2480 Notebook
What are the steps of testing the power pack on the acer travelmate 2480-2968. I am new to this and don't know much about a laptop. I just know how to use it. I have to test it with a multimeter. What is a...
A multimeter is a device that tests electrical properties of various devices and components. You use the multimeter to test the voltage of the adapter to see if is working and gives the correct voltage that your laptop requires.
Mar 03, 2009 | Acer TravelMate 2480-2968 Notebook
The laptop does not power on
I think we have a case of fried PowerSupply, test the voltage output witha multimeter, check the output printed on the brick. if that is OK then U have a Bad Motherboard.
you will need to replace it.
Jan 29, 2008 | Acer TravelMate 2413LMi Notebook
Acer TravelMate 2480-2968 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
