Need Port 7777 open
Uning my landlords connection on a WUSB600N ADAPTER. i NEED PORT 7777 OPENED FOR MY SERVER. Please help. is there any way to open this without his help? I have the usernae and passy I connect wiht but it will not take this nor the default logins info.
    Problem Solver:
  • 9 Answers
If the logins are not working that you have to log into the server to make the changes, you would need to ask for his assistance to get the port unblocked.
Posted on Mar 06, 2009
WHAT ARE THE PORT RANGES FOR ADDRESSES
Usable tcp and udp ports range from 1 to 65535. However you should not need to open any ports by default. Most routers include a stateful packet inspection (SPI) firewall. This is a fancy way of saying the router inspects the packet on it's way out to the internet when a computer on the inside of the firewall sends it out to the internet. The firewall will only allow connections from the internet on that TCP or UDP port if it returns from the original destination. For example, if you send a packet requesting the web page at cisco.com, the firewall will only allow traffic back into your network on TCP port 80 from the web server at cisco.com. If a packet from any other IP address tries to piggyback into your network through tcp port 80, the firewall will block it.
The only reason to open ports on your firewall is to allow a server inside your network to receive unsolicited traffic e.g. a web server inside your network may need TCP port 80 and 443 (HTTP and HTTPS) opened if you want to be able to access it from the internet. A mail server may need port 25 and 110 open for SMTP/POP e-mail. However, most home users do not host their own mail or web servers.
Mar 22, 2014 | Cisco Linksys Refurbished E3000...
My linksys wusb600n willconnect to my neighbors router but not mine
Try changing the channel number in the router settings and the wusb600n.
Set them both to the same number. It should tell how in the manual, If you don't have the manual for the wusb600n.it's here: Manual.
Feb 05, 2012 | Cisco Linksys WUSB600N Adapter Wireless...
How do I open the ports for mysql on my router. I have a database box and a development box and need to be able to have the development box be able to access mysql on the database box via the standard...
hi,
if you are wired as described there are no ports to open on your router. you are in the same vlan(IE:192.168.0.1/254) so no port routing is needed unless you are accessing them from the outside world which is what your router seperates you from.
however that means the systems can in theory talk to each other but you are now onto firewall rules of each system. effectivley only the mysql server need alllow inbound as outbound is usually not blocked. you can test if you are having a port issue by opening a command prompt and type telnet server_host 3306 (where server host is the ip or name of the server ) If you get a connection and some garbage characters, the port is open, If telnet hangs or the connection is refused, the port is blocked,
all that being said I would recommed you close any ports from the outside that don't absolutly need to be open.
GL
Hope this helps
please don't forget to give me a rating
Thanks
Jammer
Sep 19, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I can not access my ip Foscam FI8918W camera from internet (dyndns.org)...port forward is not clear. I have a Verizon Router Actiontec GT704WG. I am supposed to access camera...
OK let me clear port forwarding for you, your router normaly has a firewall (to block of any requests from the internet to exploit any services trough any ports) so if you want access to a resource on the LAN side (side of the router where all the devices and computers are pluged) from the WAN side (side where the ISP's modem is connected for internet) you have to open a port or multiple ports to a specific device IP address (according to device manual).
for exemple:
assuming that the camera has an IP of 192.168.1.110 and it uses port 7777 for resources, in the port forwarding section of the router you ave to open port 7777 and direct it to 192.168.1.110 (save settings and VOILA)
enjoy!
Jan 04, 2011 | Actiontec (GT704WG) Router
I get message says ( you're connected to the access point, but can Not find the internet ?
What is your OS?
The table shown below lists all Linksys adapters that will work with a Windows Vista environment.
I wonder if your OS is Win XP.Post back!
Minimum Requirements
• 400 MHz or Faster PC
• 256 MB of RAM Memory
• CD-ROM Drive
• Avaliable USB Port
• Microsoft Windows 98SE, Me, 2000, and XP
WUSB54GSC version 2.0 is compatible with Microsoft Windows XP, Vista 32 / 64-bit edition with latest updates and Windows 7 32 / 64-bit edition with latest updates
Product
Driver Vista 32 Vista 64 PCMCIA WPC54G V1 3.100.64.0 OK WPC54GR 1.0.3.0/2.0.1.9 OK WPC54GS V2.1 4.100.27 / 3.100.6 OK WPC55AG V1.3 4.1.2.38 / 7.1.0.9 OK WPC100 OK OK WPC600N 4.150.31.0 OK WUSB WUSB54GC V3 OK OK WUSB54GSC 4.1.20.0 OK WUSB54GSC V2 4.118.4.0/4.170.61.0 OK WUSB54GR 1.0.2.0 / 3.0.1.0 OK WUSB100 OK OK WUSB100 V2 4.9.9046.1 OK OK WUSB300N 1.0.7.2 / 1.0.3.2 OK WUSB600N 1.1.0.0 / 2.1.4.0 OK OK WUSB600N V2 1.4.4.0 / 2.3.4.0 OK OK
Dec 07, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys wusb600n on windows 7
WUSB600N version 2 will work with Win 7 using the Win Vista drivers.
You may refer to this link for compatible devices that work with Win 7.
You may also use the Win 7 driver - Ver.3.1.0.1.0 (32-bit, 64-bit).
Here is the link for the instructions to manually install the drivers.
Hope this helps!
Dec 10, 2009 | Linksys WUSB600N Pre-802.11n Wireless...
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
Problem open a series of ports ASUS WL-500W
Hello!
You should try to add a port range like this 7777:8000
Hope this helps!
Oct 01, 2008 | ASUS WL-500W Router (WL500W)
Wnr834b
If you tried my solution, then you would have opened all ports, so ports would not be your cause of lag at the moment. The thing is, you do not need to open any ports at all to connect to a game server, you only need to open ports when you BECOME a game server. The lagging will be down to your Internet connection, try to find a gameserver with a ping below 100. Alternatively, look for programs that consume your Internet connection like programs that are used to download MP3s and Applications as these will cause your game to lag heavily. Anyone else on the network may also be downloading or uploading, which will have an effect on your game, too. However it is most definitly not a problem with your ports.
Sep 07, 2007 | NetGear WG602 802.11g/b Wireless Access...
Computers & Internet Logo
1,059 people viewed this question
David Payne
David Payne
