Question about Acer TravelMate 2480-2968 Notebook
What are the steps of testing the power pack on the acer travelmate 2480-2968. I am new to this and don't know much about a laptop. I just know how to use it. I have to test it with a multimeter. What is a multimeter?
  • Acer Master
  • 32,281 Answers
A multimeter is a device that tests electrical properties of various devices and components. You use the multimeter to test the voltage of the adapter to see if is working and gives the correct voltage that your laptop requires.
Posted on Mar 03, 2009
  • Chris Hingee
    Chris Hingee Mar 03, 2009
    Have a look at the adapter's label and it will tell you what the output voltage of the adapter.
    If the adapter label says for example 19 volts, connect the adapter to the mains supply, turn the dial on the multimeter to 20 volts DC range and connect to red lead to the multimeter and the black lead to the common on the multimeter. With the red probe place it into the hole on the adapter's connector that plugs into the laptop and the black probe against the metal side of the same connector. Now read the voltage on the display on the multimeter, it should be the same or slightly higher that what is printed on the label. If you don't get any reading then the adapter is dead.
Acer 4320 won't power up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Possible troubleshooting steps and repair solution:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
What is a multimeter and how can i get it. Can I get steps how to test the powerpack with a multimeter on my acer travelmate 2480-2968
its a digital volt meter which also has other options. its useless when it comes to motherboards because it doesnt test caps and diods
only voltage, wiring and pos and neg detection
Mar 03, 2009 | Acer TravelMate 2480-2968 Notebook
Acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
May 30, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate
hmmm...how much juice that power pack have, and also, is battery at full charge or discharge?
Mar 20, 2008 | Acer TravelMate 8006LMi Notebook
My Acer keeps loosing power
hmm...sounds like you are suffering from a dirty power issue. how old is your house?
Mar 11, 2008 | Acer TravelMate 2300 Notebook
Wireless problem on acer travelmate 290
I feel that you have Windows XP with Service pack 1. Am I correct? If so, please install Service pack 2 for xp and your problem will be resolved. let me know. PC Expert support@techoasis4u.com
Sep 23, 2007 | Acer TravelMate 290 Notebook
Acer TravelMate 2480-2968 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
