Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Configuring linksys router
I want to configure my router, so it works properly. When I enter 192.168.1.1 in adress bar, it doesnt prompt user name/passwd screen. Instead it provides the list of different selection regarding the linksys router.
    Scholar:
  • 67 Answers
Mantoo,
Try resetting the router by depressing and holding the reset button on the back for about 15 seconds. It might be that options were set and by resetting the router it puts it back to factory default settings.
Also, ensure you have the cable from the computer plugged into the correct port for the router. It should not be in the "uplink" portion of the router as this is intended for another router. To be safe, looking at a picture of your router, you'd want to use the "2" port and ensure the cable from your modem is going into the "WAN" port.
Posted on Mar 04, 2009
How to log into mybrouter
Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below
Mar 25, 2013 | Linksys Wireless-G WRT54G Router
Change password
access your router configiration to check what is your gateway address click start button then go programs then click accessories then click command prompt. From the command prompt type ipconfigand press enter
get the default gateway address and type that into the address bar of the Internet Explorer and press enter. you will be ask for username and password you must type your router username and password. inside the router configuration you can configure/change password for your router as well as the password for your wireless.
Sep 10, 2011 | Linksys WRT120N Router
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
I have airtel brodband connection but today i bought a wireless-g (linksys) how i setup it
get the default ip address of the router which is either 192.168.0.1 or 192.168.1.1
Should be stated on the underside of the router or in the manual of the router.
Open your web browser ( internet explorer or firefox )
Delete everything out of the address bar and then enter the ip address of the router into the address bar including the dots ie 192.168.1.1 and then press enter
It should prompt you to login
the default login is admin as the username and click on ok ignoring the password field.
Otherwise it will be admin as the password and ignoring the username field and click on ok
This should take you to the web based configuration interface where you can configure all the settings for the router with regards to wireless , the ISP settings etc.
If you are unsure of what to configure in there post back with what your ISP advises to configure and I can help further.
Apr 15, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
CONFIGURING LINKSYS THE FIRST TIME
yobor4god, your best guide to setting up a Linksys router is at the Linksys/Cisco support site. I have provided a link to that page for you.
Linksys support here
Mar 23, 2009 | Linksys Wireless-G WRT54G Router
Can't find my wireless network with my desktop
open internet explorer or firefox and in the address bar enter
192.168.1.1 and press enter
then it will prompt you for a username and password
ignore the username field and enter the password as admin and click on ok or press enter.
This should take you to the configuration page.
go to the linksys site for your router here
Click on user guide - you will need adobe reader to open this so if you dont have adobe reader then you will need to install it.
Once installed you should be able to open the user guide which will walk you through how to configure the router with regards to wireless etc.
Mar 01, 2009 | Linksys WRT160N Wireless Router
192.168.1.1 the default IP Address of my router is not working.
easier to configure if direclty connected using ethernet cable not through wireless laptop or anything wireless.
type in exactly in address bar 192.168.1.1 nothing else(no http or www.) and hit enter. if this doesnt work try to hold the little button near power plug on router for about 10 seconds to reset it and try once again. If it works when you type in the 192.168.1.1 and hit enter you will be prompted for password. user is always linksys and the password by default is admin. then hit enter. now you should be in configuration pages.
Feb 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
