Question about Zebra 105Se Thermal Printer
Driver for Zebra 105se
I can't find a driver for the Zebra 105se
Hi spydo...
Zebra 105se drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Posted on Nov 17, 2014
Seagull (major barcode software) has all of the drivers that zebra does not. also found 160s driver there too. Use they installing software. works great!
Posted on Jan 14, 2011
  • Zebra Master
  • 19,396 Answers
  • 38 Answers
SOURCE: Zebra 105Se
The 105Se does not have a downloadable firmware file.
Sorry.
Posted on Mar 05, 2008
jc2it
  • 58 Answers
SOURCE: zebra 105se printer is printing out of the label on the wright side
It would be best if we had more information, or a picture.
For instance if you told me as the label is printing it does not print on the label, and it appears shifted to the right or front, then I would say, you need to re-calibrate the printer for that label.
If you were saying that the printer is printing on the right side of the label as you face the printer and watch the label exit the printer, then I would say, that the label size in the software is wrong, or the transfer ribbon is loaded incorrectly, too far to the right as you face the label exit path, OR the labels are loaded too far to the left as you face the label exit path.
Here is a link to a manual that may help as well.
Posted on Feb 02, 2008
SOURCE: Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Posted on May 20, 2008
Sakeninja1
  • 5 Answers
SOURCE: Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Posted on Mar 25, 2009
  • 35 Answers
SOURCE: My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Posted on Jan 15, 2010
I switched a Zebra printer from one computer to another. It used to print on the previous computer, but it will not seem to print on the one I switched it to. Do I need to install the printer? I do not...
You need to install the printer driver for Zebra 105Se as well as label software (if you are using it). If you are using label software, BE SURE TO USE THE DRIVER PROVIDED BY THAT MFR, as they are not interchangeable. If you are not using label software, use the ZDesigner driver from the Zebra website.
Jun 13, 2011 | Zebra 105Se Thermal Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the...
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
May 25, 2011 | Zebra 105Se Thermal Printer
Zebra 105Se not working
www.clearprintsolutions.com
Oct 12, 2009 | Zebra 105Se Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
here is manual
Apr 16, 2008 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se
Sorry.
Feb 02, 2008 | Zebra 105Se Thermal Printer
Need to increase my font on Zebra 105SE
All fonts are controlled by software. You cannot change them throught the front panel.
Steve W
LazerTek, LLC
Jan 18, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
1,463 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
