Question about Husqvarna Garden
350 leaks gas when saw is turned on side
Replaced fuel line
  • 181 Answers
As long as you used the correct diamiter of hose the hole in fuel tank will be plugged.there is also a tank breather hole in tank make sure the hose is going through to the inside of the tank.that's where you fuel leak will be coming from.the breather hole in tank.if you have any questions please contact me......
Posted on Mar 17, 2009
Gas leaks out of husqvarna 350 when in use
when you refer to using it i take that as your motor is running properly which rules out the fuel supply lines, and the primer bulb .. probaly one of two things check the gas cap and make sure it has a washer and makes a liquid tight seal and inspect the tanke for any hairline cracks that begin to drip when the motor is at idle, if it could also b the primer return line that vents back to the tank ethanol has a bad habit of eating up fuel lines on two cycles
Apr 13, 2012 | Husqvarna 350 Rancher Chain Saw
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Husqvarna 350- stopped while cutting
very straight forward to remove carb and take apart. replacing the fuel ines is a good idea. using compressed air is the best way to clean carby.
May 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 350 chain saw will only start if I manually put gas in the carb. and then it dies! I've clean the carb twice! The piston ring is within specs and the muffler is not dirty.
Typical fuel system:
8492ae1.gif Sounds as though there is a pin hole or crack in a fuel line.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. It can also be an air leak, inspect for a loose or defective carburetor manifold or loose carburetor. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH
Lou
Dec 19, 2009 | Husqvarna Chain Saw 20" Bar
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Husqvarna chainsaw leaks gas when filling
HI. IT SOUNDS LIKE YOU MAY HAVE A PROBLEM WITH THE FUEL LINE, WHEN YOU TURN IT ON ITS SIDE THE FUEL MAY BE LEAKING AROUND THE SEAL ON THE FUEL LINE OR EVEN POPED OUT. ITS HAPPENED TO ME BEFORE. JIMBO
May 18, 2009 | Husqvarna Garden
350 leaks gas when filling
HI. I JUST TOLD A GUY THAT THAT HAPPENED TO ME AND IT WAS THE FUEL LINE, IT POPED OUT OF PLACE. HOPE IT HELPS. JIMBO
May 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
344 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
