Question about Amana Heating & Cooling
AMANA PTAC NOT COOLING
Heater working AC not cooling
    Problem Solver:
  • 12 Answers
On most ptac they have electric heat so there is seperate controls for cooling it is possible a contactoer or compacitor
Posted on Mar 30, 2013
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
mastatech
  • 478 Answers
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Posted on Mar 12, 2009
SOURCE: looking for manuel reset on heater amana ptac
I have a Amana PTAC Model PTH153A50AC with the DigiSmart upgrade kit (DSUK01B) which as of last night stoped generating heat. I tried the Diagnostic and got a "LF" displayed. But I find no reference to what LF means. HELP please. Also I looked but can't find a reset button either.
Signed
House without heat
Posted on Jan 31, 2010
  • 414 Answers
SOURCE: amana ptac ac turn on
If this unit has the old style control with the knob instead of the digital control panel
then I would suspect this first. This is the first component to fail on these units. I have
replaced two already and the kit has good instructions and all components.
Takes approximately an hour to do and mount the new sensors. (The transformer is
hidden beneath the sheetmetal just below the control board). You should be able to order this kit through any appliance parts store for around 175 dollars versus almost
800 dollars for a new PTAC. Hope this is helpful.
Posted on Jun 26, 2011
Amana PTAC unit not cooling right out of the box?
If you was not transported upright, it will need to sit 24 hours before use.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 23, 2017 | Amana Heating & Cooling
My Amana PTAC unit is not cooling properly I just cleaned everything on it the coils and everything is still not cooling properly
check to see if the compressor on the outdoor unit is running, if so it could possibly have a refrigerant leak or faulty 4 way valve
Apr 27, 2016 | Amana Heating & Cooling
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
Jun 08, 2017 | Heating & Cooling
Amana pth153a35ac
The first 3 answers were from idiots. If a person had read her problem they would understand that it is not a oven / stove, but a PTAC unit that heats and cools a room. This type of unit is what is commonly seen in hotels and motels where the individual heating / cooling system is in each room.
Nov 29, 2013 | Ovens
I need a manual for a Amana PTAC model PTH123A35AC. I been looking for one & just can't find it. Please any suggestions, thanks.
Here's a good place to start: http://www.h-mac.com/brands/cooling-brands/amana.html
The Amana PTAC PTH123A35AC is obsolete and replaced by the Amana PTH123E35AXXX. The literature is similar. Search out your model # and than visit the "literature" tab to find everything's that available. Everything from service manuals to parts manuals. Good luck!
Aug 27, 2012 | Heating & Cooling
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
Amana ptac
WHAT DID YOU DO TO IT?
Sep 10, 2007 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
4,043 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
