Question about Acer TravelMate 2480-2968 Notebook
I am having a problem with my acer travelmate 2480-2968 Laptop. For some reason it will not turn on and the green light on the charger works fine, when I plug the charger into the computer the yellow light comes on(let me know that the battery is low) but it still not charging at all. I don't know if it something wrong with the computer or the battery.
  • dootruitt200 Mar 03, 2009
    How do I test the power pack can i get steps please because I don't know much about a computer.
  • 408 Answers
Test the power pack with a multimeter.  If it is not giving out the correct voltage, then your power pack is bad.  If it is good, replace the battery.
Posted on Mar 03, 2009
  • Shadow1989 Mar 04, 2009
    Get yourself a multimeter.  Set it for 20Volts or the next setting higher than what reads on the power supply unit.  Take the red lead and stick it in the middle of plug, the end of the cord that goes into your computer.  Touch the black lead to the outside of that same plug.  If it does not read the voltage indicated on the tech lable of the power supply unit, it is shot.  If you are still unsure, you can take it to your local radioshack or best buy and they will test it for you.
Having trouble keeping a charge going to Acer TravelMate 350
Remove the battery and try to run ur laptop with the charger connected to it....If it runs then it might be battery problem....
Dec 23, 2013 | Acer TravelMate 350 Laptop Charger...
I have an acer 8371 not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
If you can confirm your laptop charger is dead, just purchase a new one:
Replacement Acer TravelMate 8371 AC Adapter 65Watt 19V 3.42A
Oct 26, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
I have Acer T2300 laptop. Now where i start it after two or three days, i face problem it did start. Charger light is on but on laptop power light is also off. I show it in repairing center but they it is...
sounds like an over heating issue. i would try turning it on with battery first then plug it in or vs versa turn it on with just power cable not batter then add battery. since you did say it did turn back on i would also be worried about a loose connection for power from the cord to the pc and clean the battery terminals.
Mar 15, 2011 | Acer TravelMate 2300 Notebook
Acer Travelmate 2480-2968
You might have to try an new a/c adaptor.
Mar 09, 2009 | Acer TravelMate 2480-2968 Notebook
Acer Notebook 4330 No Power/No Charge
If the Notebook is only 1 month old i suggest you bring it back and see if they will replace it. Most likely the problem (for how you have explained it) is that the DC power pin (inside the notebook) is either broken or not soldered to the mother board correctly.
Being only one month old this is probably a faulty pin or installation from the manufacturer so this should not be a problem for the place you got it from to replace.
If you do have problems I suggest contacting the manufacture immediately to see if they will replace it.
I hope this helped
Have a great day.
Jan 28, 2009 | Acer TravelMate 2480-2968 Notebook
Laptop Acer does not see AC power
ok..try it without the battery installed at all, and let us know how that works..AC power only..
Mar 23, 2008 | Computers & Internet
Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Feb 27, 2008 | Acer TravelMate 2300 Notebook
My laptop not start at all
do the fans turn? Can you hear the hard drive turning? Looks like a motherboard problem Try without the battery and only the charger
Sep 25, 2007 | Acer TravelMate 2355LCi Notebook
Acer travelmate 270
I had the same problem and it was my battery - i would strongly suggest getting a new one, doesnt need to be an ACer - it could even be a generic one- just as effective.Try www.cellphoneshop.net, they sell cheap batteries.
Aug 31, 2007 | Acer TravelMate 270XV Notebook
Acer travelmate 8204WLMi charging problem
the only repair centres are in uk that give you the turn your laptop arround in the time you need if you type in laptop repair centres in search browser and you get all repair centres listed. I've hunted for 20-30 mins on repairs to laptops in USA but not much available on your laptop model. good luck on finding a service centre for your laptop
Aug 15, 2007 | Acer TravelMate 8204WLMi Notebook
Acer TravelMate 2480-2968 Notebook Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
