There is a narrow padding strip that runs under all the keys going across. It is made of a type of felt. It is worn or torn in that spot. If you are careful and have some mechanical skill at opening the unit, you will see it, it should be a pretty simple fix to glue the felt back (if torn) or even to glue a small piece of felt in that spot to raise the key, which will allow full movement again so it would feel pretty close to normal again.
Has a narrow fill run under all of the keys to cross. It is a type of
felt. This is the wear and tear. If you are serious, and has certain
mechanical technology, in the open unit, you will see it, it should be a
very simple solution to glue the feeling of back (if tears), or even
stick on a piece of felt at this point to improve the key, this will
allow movement fully, so will feel very close to normal.
Barbed Wire
SOURCE: the keys in the middle
Although the keys have a weighted feel, this is not because of a system involving connection t hammers as in an acoustic piano. This is done mechanically, however, which would indicate a need for cleaning. If you have an authorized Yamaha service center in you area they would need to do the cleaning.
SOURCE: key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
