Question about Tappan TGFS_63 Gas Kitchen Range
The oven sounds like blow torch
Sometimes when I turn on the oven it sounds like a blow torch...it also takes forever to come up to temp when the blow torch noise isn't happening
  • leenie312 Mar 03, 2009
    Ok...I figured it was either too much or too little gas...so now that I know what it is...how do I fix it?...what part needs to be replaced...how difficult is it to fix?
It could be the FSD(flame supervisery divice)not opening correctly starving the burner of gas.
Posted on Mar 03, 2009
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
When oven was 1-year old, the lower oven started making a noise that sounded like a blow torch, usually after being on for a little while. It was (after many service calls) repaired by replacing the...
Hi Nancy
I have to ask you a couple of questions. Is the range set up for LP or Natural gas? Blow-tourch sounds are normally caused by to much air going into the burner. If you can look at the burner safely the flames should burn just out of the burner. If the flames are way off the burner the air adjustment is way off or you range is set for the wrong gas. Are your top burners OK?
Sep 13, 2010 | Maytag Kitchen Ranges
Oven will not keep temp and making gas noise
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 04, 2010 | DCS RGT-305 Gas Kitchen Range
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
Desa TT30G Heater turns in to a blow torch
hi there
OK i read your report. when this happens again adjust the valve until you don't hear the blow torch noise. Because you could have had your valve open to far and that would make that noise. Try that and let me know.Thank you for writing to fix ya.
Best Regards Richard
Nov 28, 2009 | Desa International TT30G Heater
My Kenmore gas oven sporadically takes forever (30+ min. to heat up to 350 degrees). Sometimes it works fine, & other times it takes at least 1/2 an hour. Also, I periodically smell natural gas when I...
Sounds like a weak ignitor. If it doesn't get hot enough to allow the proper amperage through to the gas valve, you will have this symptom.
Jul 25, 2009 | Kitchen Ranges
Tappan TGFS_63 Gas Kitchen Range Logo
930 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
