Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Wiring details on a Case 424 lawn tractor with K321A Kohler motor
Did engine work on a Case 424 lawn tractor. It has a K321A Kohler engine and the generator is now heating up when used. My guess the wiring is incorrect and I would like to know which wires are the proper ones to the generator and the voltage regulator from the Kohler engine. A diagram would be best so I can compare to what I have already set up and what is correct or possible color coding. Yes, the battery is hooked up properly. I can see no problems other than the possibility of wrong wiring.
  • mamicheddy
    mamicheddy May 11, 2010
    I will need model off the genset and serial number. Plus, what do you mean the genset is heating up? Are wires heating up, like a short.
3 Suggested Answers
SOURCE: electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
I need a diagram of the electrical system for a cv15s kohler engine that is mounted on a lg 155 John Deere riding mower. The engine will not turn over, even though I have a new battery. The last time I mowed the engine would barely turn over, now it will do nothing but make aquiet click when I turn the key with the brake compressed. Any ideas?
Posted on Jun 28, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Dec 02, 2012 | Garden
Can I add an hour meter to my Crafstman 917.289340 lawn tractor with the 22 HP Kohler engine? Found a part #401763 for a different model Craftsman. Will it work?
Yes, you need to find a wire that is hot (12vdc) when the engine is running, tap into this wire and hook to the positive side of the hour meter and the other will be a ground. This will keep track of engine hours only. If you want complete total hours, any hot wire with the switch on will work.
Feb 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Electrical wiring for kohler engine
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Changing from kohler 12.5 to kohler 14hp
Go to http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Type in your model no. and serial no on mower. Locate correct manual, you will then have to trace wires on both motors and make them correspond.
Mar 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
356 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
