Question about KitchenAid KSM50PR Professional Series Stand Mixer
I can't get the bowl onto my KitchenAid Pro mixer
The mixer fell off the counter and one of the arms that hold the bowl in was bent inward so it is too tight and I can't put the holes on the bowl over the pin on that side. I can't bend it back out. Is it repairable and how much approximately will it cost? It is a refurb and I'm wondering if it would be cheaper to get another.
  • 135 Answers
Hi. I'll give you the cheap/fast solution first. Get a 2-3 ft. section of metal pipe that will fit over the bent arm, gradually, incrementaly and slowly bend the arm out using the pipe. check it at each increment for fit and level.
Now for the more expensive/slow solution. Find the nearest Kitchenaid "approved" repair service store. You will then be looking at a replacement bowl support and the labour to repair it. Be prepared to wait for up to a month for Kitchenaid to fill the parts order. If you find that these solutions have assisted you, please rate them. Good luck! ricardok45
Posted on Mar 06, 2009
Jeans mixer needs a check its less then 1 year old
Contact Peter McInnes or hop onto their web site
Jan 28, 2014 | KitchenAid Food Mixers
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
Beater hits side of bowl
There may be a few problems that are occurring here. However, in the past I have seen that the bowl has become misshapen after repeated use and normal wear and tear. Some times if the bowl isn't too bent you can re shape it by rolling it on the floor or a counter. Hope this helps!!
Thanks. Grant
Feb 20, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My KitchenAid mixer clicks when I mix bread dough and any other thick batters. How do i fix it?
Make sure your dough hook isn't bent.... or your bowl doesn't have a dent in it.... and make sure the bowl is properly seated and secure.
Aug 29, 2010 | KitchenAid K45SS Classic Stand Mixer
My 6 quart kitchenaid mixer paddle is rubbing the bottom of the bowl with the tip of the paddle and turning my product black
Find the screw in the picture as shown and screw it counter-clock-wise which will drop the bowl level down when it is in the raised position and the mixer paddle will not rub on the bowl.
May 21, 2010 | KitchenAid RKG25H0XWH Mixer
Beater hitting bowl. Very wobbly, won't stand still when
More likely the pedestal base is bent. Your local service agent has probably seen it before and should be able to bend it back flat again. It's a brutal process with a heavy soft hammer that you probably won't want to see.
Jul 15, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid mixer fell off the counter - thumbscrew
Yes, the upper case is available as a seperate part. Any authorised KitchenAid repairer should be able to get hold of the part and make the repair.
Jul 03, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 300 Watts KSM90 Ultra Power sparking
Sparking is a safety concern and Kitchenaid will see it as such. I would suggest calling Kitchenaid Customer Service. They are likely to exchange the product, regardless of warranty or age, because of the potential safety concern.
Their toll-free telephone number is 1-800-541-6390.
May 31, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Kitchenaid Pro 6 Bowl Support bent?
Hi. Your mixer should still be under warranty. Call Kitchenaid Customer Service and tell them your story. If you tell them that you tried to fix it by spreading the arms, your warranty will be deemed void. Kitchenaid is usually very good at replacing under warranty. If you found this solution helpfull, pleas rate it Good luck! ricardok45
Jan 10, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM50PR Professional Series Stand Mixer Logo
81 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
