Question about Toshiba Satellite A10 Notebook
Hard drive specifications for Toshiba A10 laptop
I need the exact specifications for a hard drive for this model. It is 5 1/2 yrs. old and model nr. is PSA10E-012SY-NO. It has a 30GG hard drive which I want to replace.
Storage size I can determine myself.
Are IDE and ATA the same thing?
Thanks
  • 408 Answers
IDE is the flat 40 pin cable about 2" wide.  Other than that it could be SATA, which is a small, plug.  About 3/4" inch by 1.8".  Take it apart and see what cable it has.  Pretty much any hard drive will fit providing it has the same cable attachments.
Posted on Mar 03, 2009
I need all drivers for Toshiba laptop Satellite A10 psa10 00reh. thanks
Is there a way to do this exact manipulation with a bootable CD\DVD ?
Aug 16, 2012 | Toshiba Satellite Computers & Internet
What is the exact part or item number or description of the internal hard drive of a toshiba satellite L305-S5924? mine needs replacement and i want to get the exact original compatible part
You do not need the exact part number, your laptop came with a 160GB 2.5" SATA drive.
Any 2.5" SATA laptop drive will fit and work with your laptop. A 500GB drive can be bought for £30.
Take a look on Amazon.
If you want an exact replacement, take your old drive out and search on google for the model number it will have on it
Oct 24, 2010 | Toshiba Satellite L305-S5924 Laptop
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          How to replace dvd rom drive.NO release button on base!
          Firstly there is a screw on the underside of the laptop that needs to be removed.I ts is located on the edge of the drive.
          Next the keyboard needs to be removed. To do this, remove the strip at the top of the laptop containing the power butto by inserting a small flat blade screwdriver at under it and prising it up.
          After removal, undo the three screws holding the keyboard and flip the keyboard over.
          Undo the screw that holds the keyboards strap securing plate and then slide the drive out.
          Be warned though that not all drives work in these laptops. It has to be the exact type for the machine as most do not work.
          Assembly is the reversal of the above.
          Hope this helps.
          Feb 08, 2009 | Toshiba Satellite Pro A10 Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          Laptop will not boot
          try to remove the ram then hard drive. now remove the batteries then insert the ram back without the hard drive, power yr system directly from yr wall sucket without batteries n see what happends. i think i should power on. other wise try using a dissferent ram on it.
          thank uy
          May 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
          Hard disk
          not too hard..should be a couple of small cross screws under the bottom, just remove them, and slide out the old drive..
          May 12, 2008 | Toshiba Satellite A10-S100 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Toshiba Satellite A10 Notebook Logo
          301 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
